Car Doesn't Want to Start
Old Jun 19, 2007 | 07:44 AM
tenblade2001's Avatar
I have a 2004 6MT coupe. The last couple of days the car has been acting up whenever I go to start it. I turn the key and everything powers up, but the car doesn't immediately turn over.... I have to turn the key again. Then, this morning, I drove the car about 2miles, stopped for coffee and when I went to restart it, the damn thing wouldn't turn over. Again, everything powered up, but no turnover. I waited a couple of min. and it started up.
Suggestions? Any help would be appreciated, since I am supposed to move to Dallas (fromr VA) and will be driving.
Old Jun 19, 2007 | 09:13 AM
Mark350GT's Avatar
When you power the car do you hear the fuel pump engaging?
Old Jun 19, 2007 | 09:52 AM
617G's Avatar
CFW (Carbon Fiber Whore)
+1
1. Check to see if you hear the fuel pump
2. Check to see if you hear the throttle body open and close
3. Check your plugs
Do you have throttle response while you start the car? Try turning it over with the pedal all the way to the floor. This won't start the car, but it will clear any excess fuel in the exhaust.
Old Jun 19, 2007 | 09:53 AM
Hi-TechG35's Avatar
^Agreed.
Old Jun 19, 2007 | 10:04 AM
allforthecash's Avatar
When you say it doesn't turn over do you mean that it does NOT crank at all? or it cranks but does not start up?
If it doesn't crank...starter may be bad (dead spot)....
Old Jun 19, 2007 | 10:53 AM
gao's Avatar
gao
as mentioned, there are also a few other things u can check for connectivity and wear and tear, spark plugs, coils, coil wires, starter, fuel pump, fuel filter...
what maintenance and when have u done so far?
Old Jun 19, 2007 | 11:47 AM
it doesn't crank at all. I can hear a click but the engine even attempt to crank.
Old Jun 19, 2007 | 11:52 AM
KPierson's Avatar
If you hear a click but the motor doesn't crank I would suspect the starter. I doubt it is the battery, as it sounds like if you fiddle with it it will start up eventually.
The 'click' that you hear is most likely the click of the solenoid that drives the starter. The 'click' confirms that the ignition switch and wiring is OK. Next time it gives you problems throw the car in N and move it bac 6-12" and try to start it again. If the starter has a 'dead spot' in it like mentioned above this will get you around it.
Old Jun 19, 2007 | 01:37 PM
Castro's Avatar
Also a light tap with a tire iron gets a bad starter to cooperate for the short term.
Old Jun 19, 2007 | 02:46 PM
joe603's Avatar
I've seen the ignition switch go on these cars...take it to the dealer if it's under warranty.
Old Jun 19, 2007 | 04:23 PM
g35rcr's Avatar
crank sensor could be bad...i had it happen on another car, it would crank but not start and all the electrical would turn on
Old Jun 19, 2007 | 05:52 PM
KPierson's Avatar
It will still crank with the crank angle sensor being bad. According to the service manual, it will still run with a bad crank angle sensor (but in batch injector firing mode, not sequential).
Old Jun 20, 2007 | 11:20 AM
then its the starter!!! ...you can try knocking it around to get it started....
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
newg37
Jul 26, 2015 09:32 AM
BlackGee35
Jul 21, 2015 07:24 PM
realtalk21
Jul 20, 2015 09:07 AM
