screeching noise at start up?
Old Jul 15, 2007 | 02:48 PM
ac419's Avatar
anyone have this problem? i noticed after having my UR pulleys installed, when i start my car, i always hear a screeching noise. anyone else have this problem and know how it can be fixed? thanks.
-alex
Old Jul 15, 2007 | 07:38 PM
Mapester's Avatar
It may be a belt problem, they may need to be lubed or replaced. I replaced my belts and it solved the problem.
Old Jul 15, 2007 | 07:43 PM
juy's Avatar
juy
if its still under warranty, take it to the dealership. they will just replace the belt or pulleys. i had the same problem not to long ago and they took care of it in a day.
Old Jul 15, 2007 | 08:26 PM
ac419's Avatar
the thing is that.. i have aftermarket pulleys so yeah..
Old Jul 15, 2007 | 08:33 PM
Mapester's Avatar
Your in SoCal, take it to infiniti riverside, they are much more friendly about aftermarket parts.
Old Jul 15, 2007 | 08:38 PM
ac419's Avatar
do you know any other infiniti mod friendly dealerships? riverside is a long drive for me.
Old Jul 15, 2007 | 08:42 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
west covina nissan is mod friendly.
-GP-
Old Jul 15, 2007 | 08:49 PM
DaveB's Avatar
The belt is slightly loose. It takes all of 2 minutes to tighten yourself or $80-100 to have the dealership do it.
Old Jul 15, 2007 | 08:51 PM
ac419's Avatar
how do you tighten it? thanks.
Old Jul 15, 2007 | 08:57 PM
the belt could also be cracking, causing it to squeal. If it is, then no use tightening it as it needs to be replaced anyways.
You need to have enough room to get under the car, take off the splash shield. Then loosen the tensioner pulley's with a 14mm (1 turn is enough) then tighten the belt buy using a 12mm socket on the adjusting bolt. Then tighten the pulley back up and you're set.
-GP-
Old Jul 15, 2007 | 09:02 PM
ac419's Avatar
haha too much of a hassle for me. i think the belts are still in good shape (brand new with the UR pulleys) i think i'll take it in. thanks
Old Jul 16, 2007 | 01:46 AM
ac419's Avatar
thanks everyone.. it's fixed. just need some good ol' wd40
Old Jul 16, 2007 | 06:11 PM
DaveB's Avatar
Uhhhhh....not good. Now the belts will really be prone to slipping and sounding like a stuck pig. You have also now introduced the potential to actually throw a belt if the WD40 gets between the tensioner and belt. Ribbed accessory belts don't take to belt dressing kindly. I suggest your remove all the belts that were sprayed and throw them away, scrub the pulleys to remove all WD40 residue, and then install new belts.
Old Jul 16, 2007 | 06:15 PM
zackt69's Avatar
rarejdm.com
+1... don't spray lube on the belts, you want to keep them clean to prevent slippage. Plus the wd40 might actually cause the belts to break down and crack prematurely.
Old Jul 17, 2007 | 02:46 AM
ac419's Avatar
damn! stupid uncle... should of never listened to him.
what kind of lube would you put on it because it seemed like the sound is gone now.
