Throttle Body?????
Old Sep 12, 2007 | 02:38 PM
D's06G's Avatar
Throttle Body?????
I was planning on changing my throttle body but i know no one has made a bigger one for our cars but i did hear that you could use a Q45 throttle body which is 90MM. So has anyone tryed this out or heard anything about this? Please help me out. Thanks guys.
Old Sep 12, 2007 | 02:40 PM
redlude97's Avatar
top secret has a larger throttle body for our cars
Old Sep 12, 2007 | 02:42 PM
D's06G's Avatar
oh really??? i didnt know that are they any good?
Old Sep 12, 2007 | 02:47 PM
D's06G's Avatar
Wow i just checked out the throttle body holy crap thats expensive!!! anything else a little less expensive?
Old Sep 12, 2007 | 02:48 PM
bull3t's Avatar
you could get a throttle body spacer
Old Sep 12, 2007 | 02:50 PM
D's06G's Avatar
yeah i have heard alot of stuff about that. but i hear some ppl say it works and some say no it doesnt so not to sure about that...
Old Sep 12, 2007 | 03:37 PM
M@rCo's Avatar
If you search there was a lengthy thread about this from a few people who had installed them and tested them on their cars.
Old Sep 12, 2007 | 03:45 PM
GreenGoblin's Avatar
The goblin resurrection
huh that is pretty sweet setup i would like to know about the q45 throttle body is there a thread about this if so can some one throw up the link I couldn't find it
Old Sep 12, 2007 | 04:09 PM
M@rCo's Avatar
https://g35driver.com/forums/showthr...+throttle+body
thats the thread i was referring to...not about a Q45 TB....but if youre looking to know about TB spacers that might help
Old Sep 12, 2007 | 04:10 PM
g35rcr's Avatar
a larger throttle body will do nothing on the car stock unless you have an aftermarket tuner and are going fi
Old Sep 13, 2007 | 11:59 AM
Q45tech's Avatar
Before you waste time and money on TB replacement do some scientific research and measure the WOT resistance of the oem unit...............you will find it to only create 3"- 3.5" water column of resistance to earth's supercharger [14.7 psi].
3" w.c. is 3/27.7 or 0.108 psi or 0.7% resistriction.
The MAF is double [~~7"] this...............from intake valves thru runners, thru plenum thru ducts, thru MAF, thru air filter thru air intake housing the entire system is less than 1.0 psi ~~25" worse case which ~~6%
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
