6th Wire on Grounding Kit
Old Feb 8, 2004 | 11:34 PM
marvinclt's Avatar
Can someone get me some specific instructions on this. Sorry not to put this on the huge thread, but I fear that this would not get answered. I bought the kit from z-xtreme and wires 1-5 were clear, but 6th was a little vague since pics on the other thread made it unclear as to where it goes.
Also, I busted those tabs that are used to hold the wheel liner. I would appreciate some direction to get some more.
btw, after installing 1-5, I noticed a big difference. Definately smoother. HP gains...might be psyc, but I do notice some.
TIA.
Old Feb 9, 2004 | 12:19 AM
DaveO's Avatar
Re: 6th Wire on Grounding Kit
I believe I can help with the tabs. Nissan calls them "Clips" and they're available from your local friendly Nissan/Infiniti dealer. The part number is 01553-09321. The picture is larger than the actual size.
Sorry I can't help with the z-xtreme kit's 6th wire. I have GordGee's 7-wire Ground Gear kit and the connection points may be different.
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Feb 9, 2004 | 10:31 AM
marvinclt's Avatar
You da man! Or at least half, since you answered 1 of 2 =) (jk) Thanks.
Old Feb 9, 2004 | 10:34 AM
Gordgee's Avatar
Administrator
I'm not positive, but I believe that Z-Xtreme runs the 6th wire from the right rear of the intake plenum to the bolt holding the factory ground on the right strut tower. E-mail him to make sure. Hope that helps.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Feb 9, 2004 | 10:49 AM
marvinclt's Avatar
After some major research, I think your right. I noticed that some ppl were running the sixth wire from the front of the plenum where 1,3 and 4 are connected. Is there a reason why ppl are doing that instead of the back of the plenum?
Old Feb 9, 2004 | 01:51 PM
Gordgee's Avatar
Administrator
GroundingGear™ runs it from the front of the engine plenum. I believe that the front cluster is a more important point for signal information (at least in theory) based on empirical data and consultation with Electrical Engineers. The difference may be marginal, but everything GroundingGear™ does is based on theoretically maximizing the signal, from materials used, construction technique, to grounding points and configuration. After all, isn't this what it's about anyway?[img]/w3timages/icons/smile.gif[/img]
For more info:
Hyper-Ground FAQ Thread
Old Feb 9, 2004 | 06:50 PM
tonio's Avatar
I used that same grounding kit on my 6MT a week ago, I just ran it from the front of the plenum and it works just as well
Old Feb 14, 2004 | 03:52 PM
GLuvin's Avatar
Z-Extreme's 6th wire goes from the same Plenum bolt as wire 5, under the intake tube to a 10mm bolt that has a flat ground wire on the inside of the whell well. You can see it well if you remove the intake tube.
03 - Black - Premium - Wood - Aero w/ Spoiler - Z Tube - Grounded - Stillen CAI
Old Feb 16, 2004 | 01:18 PM
GLuvin's Avatar
I must correct my last post, I ran it wrong myself. Check out this thread for a pic of the 2 grounding locations on wire six.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Feb 16, 2004 | 04:07 PM
marvinclt's Avatar
Thanks for the post GLuvin.
Nice setup ;-). (My G - wood trim = Your G)
zoop425
Mar 29, 2016 05:51 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
linedr89
Aug 17, 2015 05:11 PM
