VQ Engine - MPG Comparisons
Old Feb 9, 2004 | 01:39 PM
Noremac's Avatar
Since there is so much talk about gas mileage with the G35, I thought it would be interesting to compare all the Nissan models with the VQ engine. The color bars show relative position in the model lineup. (In some cases, I've averaged GVWs for typical options). And remember, YMMV!!!!
'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat
Old Feb 9, 2004 | 01:42 PM
Noremac's Avatar
Re: VQ Engine - MPG Comparisons *DELETED*
Post deleted by noremac
Old Feb 9, 2004 | 02:38 PM
Gordgee's Avatar
Administrator
Nicely done! I wonder why the Max gets better mileage than the Altima?
<font color=green>GroundingGear™ Equipped </font color=green>
Old Feb 9, 2004 | 03:34 PM
Noremac's Avatar
<hr></blockquote>
It may have something to do with the final drive ratio. Also, the EPA ratings can be a mystery sometimes!
Old Feb 9, 2004 | 03:54 PM
DaveO's Avatar
Question.
The weight for the G35 6-speed Sedan is close to the Infiniti spec curb weight. The weight for the G35 AT Sedan is much higher than the published curb weight. Could it be the actual weight with a full tank of gas and maybe a driver?
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Feb 9, 2004 | 04:17 PM
Gordgee's Avatar
Administrator
How do the manufacturers determine the spec curb weight anyway? Full tank? Half tank? With or without driver? Do all manufacturers do it the same way?
BTW, do you happen to know what the AT sedan weighs and how did you determine it?
Thanks
Old Feb 9, 2004 | 05:08 PM
hotg35's Avatar
Without final drive ratios the chart means nothing.
Old Feb 9, 2004 | 05:18 PM
Noremac's Avatar
Here is a better graphic with an added Torque/MPG comparison column.
Old Feb 9, 2004 | 05:21 PM
Noremac's Avatar
<hr></blockquote>
I'm not sure what you mean. The curb weights used in the table are directly from official Nissan/Infiniti sources. What other info do you have?!
Old Feb 9, 2004 | 06:15 PM
DaveO's Avatar
The new G35X must have been quoted.
From Infiniti's website - http://www.infiniti.com/content/mode...,30648,00.html
G35 Sedan
Curb weight
Base model 3,336 lbs
Leather model 3,369 lbs
Leather 6MT model 3,398 lbs
AWD Leather model 3,677 lbs
Old Feb 9, 2004 | 06:32 PM
Noremac's Avatar
I didn't use the base (non-leather) model. Otherwise, all the others are exactly as you quote!
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
