Plenum question
Old Sep 24, 2007 | 03:19 PM
JfromTheBay's Avatar
Plenum question
im on everythingG35.com and am looking to get a plenum spacer 1/2"
they have 3 different choices
1/2" Copper ISO Thermal Plenum Spacer
1/2" ISO Thermal Plenum Spacer
1/2" Plenum Spacer
they say to use the copper one if it snows in your area....i doesnt snow here i drive to snowy areas at times
Whats the thermal mean does it only induct cold air?
would really appreicate some input
Old Sep 24, 2007 | 03:38 PM
Deepdiver's Avatar
5/16" iso FTW! The iso helps to allow less heat transfer to the intake manifold and lower plenum.
Old Sep 24, 2007 | 04:05 PM
g35sedan5at's Avatar
1/2" iso FTMFW! lol....why is everyone caught up on the 5/16. i know its the best bang for buck but dont hate on the 1/2 just cuz its a little overpriced.
Old Sep 24, 2007 | 04:10 PM
Deepdiver's Avatar
although the 1/2" produces a slightly higher hp peak, the 5/16" has better performance over the useable power band range.
Old Sep 24, 2007 | 08:02 PM
Hydrazine's Avatar
The Iso Thermal is good for another 1-2 HP on top of what the spacer does.
And yes, if you regularly drive in or to snowy areas, I do recommend the Copper version.
The copper heats only the throttle body and allows the rest of your plenum to run much cooler. A cooler running plenum allows for cooler/denser intake air charges for your engine. It also helps reduce the tendancy for ping.
More importantly, you don't have to switch anything on or off like you would have to do with the Coolant Control Valve. Its all automatic. Set and forget.
Tony
PS - Do you have a REVUP or non REVUP engine? Manual or auto?
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
Raven7
Aug 14, 2015 04:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
