Is it ok to tap into this wire???
Old Sep 26, 2007 | 09:31 PM
rocsell's Avatar
I'm using a pic from sean@riversideinfiniti for this post...FREE advertising for him
I recently installed a Daytime Runing Light kit on the car...1-wire for ground, 1-wire tapped into the fog lights and 1-fused wire connected to the battery.
I was also supposed to wrap the SIGNAL wire around a spark plug wire (or other 12v source)...I tried wrapping it around one of the Coil wires, but this didn't work so I decided to tap into another wire I found which was live only when the key was turned to ON. This is the wire/connector that is circled in RED in the pic at the top of the engine bay. I just want to make sure that I'm not screwing anything up by tapping into this wire...is this OK guys??
Old Sep 28, 2007 | 03:30 PM
rocsell's Avatar
Hey moderator's, please remove if this is in the wrong section...
Old Sep 28, 2007 | 03:39 PM
g35rcr's Avatar
isnt that the wire for the throttle body? if it is i wouldnt do it
Old Sep 28, 2007 | 03:44 PM
SxExCx's Avatar
hey..thats my engine! sweeeet!
Old Sep 28, 2007 | 03:54 PM
EricIsKlumzyee's Avatar
lol no do not tap that wire.. tho if you want to make sure..
get a volt meter and see if the values change upon start up or driving.. if it stays 12v all the time then its a power wire and u may tap into that
- Eric
Old Sep 28, 2007 | 04:07 PM
rocsell's Avatar
- Eric
Yes, it is a power wire...just didn't want to mess up anything that thiswire is connecting to (not sure what the heck this is)...
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
