Pully set (noob?)
Old Nov 22, 2007 | 01:42 AM
npecora's Avatar
Pully set (noob?)
ok im looking for easy bolt on performance mods. is changing the pullys a good mod?
would i have to change anything or can i just swap out pullys and belt?
Old Nov 22, 2007 | 02:00 AM
CHECHERS's Avatar
intake or plenum spacer are a good and easy start. you get noticeable increase in power and it is easy to do
Old Nov 22, 2007 | 02:22 AM
npecora's Avatar
i have an injen intake already. so you are saying a plenum spacer is should be my next mod? will this void warrenty?
Old Nov 22, 2007 | 03:22 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
intake voided your warranty. who cares.. lol
Old Nov 22, 2007 | 03:24 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
dont waste your time with pulley's they're not worth the money or the hassle of the install. and wont gain you any noticeable power.
-GP-
Old Nov 22, 2007 | 10:14 AM
CHECHERS's Avatar
As far as warranty goes, I believe what ever part you replace on your car the warranty is voided for that specific factory part. Now if the maintanace staff can prove that your aftermarket part caused other engine components to fail or work properly they may be able to void the warranty for more parts. That is how I remember it.
Old Nov 22, 2007 | 03:40 PM
npecora's Avatar
so plenum is what im getting...... thanks
as far as warrenty all i have to do is remove mods before i take it in lol......
now do i get a new plenum or just the spacer?
Old Nov 22, 2007 | 06:53 PM
CHECHERS's Avatar
Motodyne Plenum Spacer is what you want to get. Thats next on my list
Old Nov 23, 2007 | 12:51 PM
brownfv's Avatar
If you want to do pullies, all you need is a new crank pulley and not the whole set.
you can either get one with the stock size, or underdrive. the difference is probably 1-2HP, but with the stock size you can keep using the standard belt size.
i have the UR stock size pulley and i felt noticeable gains in the low-mid range, and to be honest the gains felt similar if not equal to what i felt with my 1/2" spacer.
Old Nov 23, 2007 | 07:21 PM
citymunky's Avatar
+1
I have the UR underdriver set, and I noticed low-mid range gains, but nothing to
say OMG!!. The UR crank weights like 4-5 lb less than the stock crank.
Old Nov 23, 2007 | 07:52 PM
npecora's Avatar
thanks guys
i think i will get the spacer first...
Old Nov 23, 2007 | 10:30 PM
citymunky's Avatar
If you have a 2005 & Up 6MT, get the MREV2 with the Spacer.
Old Nov 24, 2007 | 12:10 AM
jonnylaw's Avatar
Def go for the proven and cost effective mods first like md spacer/mrev2. The stock size ur pulley set was one of my last mods. Honestly I haven't noticed much performance increase, but strangley I have experienced less nvh, which is great, but I was expecting the opposite result. Make sure the crank pulley has a pressed steel insert and is installed correctly and carefully.
Old Nov 24, 2007 | 12:24 AM
brownfv's Avatar
+1 those should be your starting mods and go from there...intake, spacer + MREV, sway bars, etc. after your bolt on's a good tune will be a great "mod" as well.
Old Nov 24, 2007 | 12:41 AM
npecora's Avatar
thanks guys...
i have an 05 auto so all i need is spacer right?
or does the spacer go with mrev2?
