Torque Wrench
Old Nov 30, 2007 | 01:16 PM
gte959s's Avatar
20 Year Member
Question Torque Wrench
Where can I find a reasonably priced torque wrench that covers
40 in/lbs
in Atl. GA? I checked local autoparts store and they only had torque wrechs that went down to 120 in/lbs. I have a torque wrench that does FT/lb's but it only goes to 30 ft/lb which is 360 in/lb. ANy definite places? and how much?
Old Nov 30, 2007 | 01:20 PM
EricIsKlumzyee's Avatar
sears...
torque wrench ranges.. i wouldnt trust the cheap cheap ones unless its the old school one with the needle lol other then that i'd fork up the $$
Old Nov 30, 2007 | 01:35 PM
gte959s's Avatar
20 Year Member
what about this one?
http://www.sears.com/shc/s/p_10153_1...rque+wrench+in
its $70
Old Nov 30, 2007 | 02:40 PM
fortified's Avatar
Unless you are a professional mechanic and expect frequent use, that should be a good one!
Keep it clean, and don't drop it. Should last a long, long time.
Old Nov 30, 2007 | 04:00 PM
ttrank's Avatar
Grocery getter
Most of those Sears ones are crap. Read the reviews, even the ones on the sears site!
I get Snap-on, Matco or other good brands off ebay.
Old Dec 2, 2007 | 06:44 PM
Still2Slow's Avatar
Whatever you do get a nice one. I've been betrayed by the cheap ones from autozone.
Old Dec 3, 2007 | 11:01 AM
Q45tech's Avatar
Be sure to annually have the wrench calibrated.
http://www.advancedtorque.com/calibration/index.html
http://www.sacskyranch.com/torquew.htm
Old Dec 3, 2007 | 11:10 AM
istan's Avatar
Originally Posted by gte959s
Damn, that was on sale last week for $40.
Old Dec 3, 2007 | 12:41 PM
st1sj's Avatar
where do you go to get the torque wrench calibrated?
Old Dec 3, 2007 | 03:22 PM
^ bring it back to where you bought it?.. I'm sure there are tool shops that'll do it for you but I had my Snap-On one recalibrated by snap on for $40 =)
Doesnt matter if you're a tech or not.. ALWAYS buy a good torque wrench.. cheap ones = stripped bolts/snapped bolts/improper torque..
like I said in my first post here.. if you're looking for a cheap one buy the old school one with the needle.. its ALOT more accurate then a cheap torque wrench
+1 on sear's wrench being ****ty.. from my experience its a hit and miss.. I've bought a inch-lb torque (seeing how I dont use inch lb much at all) for $50 two years ago during a christmas sale.. the thing was CRAPP the adjuster was very hard to move and wouldnt return to 0 anymore after 1 use ._. I exhcanged it.. this one broke after two weeks -__-.. finally the third one (exchanged again) is working great til now =)
Old Dec 8, 2007 | 08:47 PM
n1cK's Avatar
G35 6MT
Originally Posted by Q45tech
+1 on getting it calibrated. you can buy the most expensive, most super wamadyne torque wrench on earth, but you should still get it calibrated, especially if you use it all the itme and live and die by torque specs.
technically, you should have it calibrated by an ASAL certified place upon purchase, and then early thereafter. this assures that you will meet the spec at all times. it's only about $25 (depending on the size) to get it calibrated. just think of it as a yearly maintenance item on your tools.
Old Dec 8, 2007 | 09:18 PM
st1sj's Avatar
is the cheap torque wrench from tirerack worth calibrating? http://www.tirerack.com/accessories/tools/tw605.jsp
Old Dec 8, 2007 | 10:11 PM
n1cK's Avatar
G35 6MT
only if you are how accurate it is...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
Raven7
Aug 14, 2015 04:40 PM
