Need some Help
Old Jan 26, 2008 | 01:42 PM
Murrayes_754's Avatar
Exclamation Need some Help
So when i start my car my lights and fans just turn off and on...? And the speedo and tec don't work. If i sit there it doesn't do it as much once it heats up.. and out of what may be luck it all started after i got a flat.. but the biggest thing is that the Speedo doesn't work, the tec jumps when i first start the car but then it goes to zero..checked all the fuses and the battery connections,... Any one have any idea's...?
Old Jan 26, 2008 | 02:20 PM
g35rcr's Avatar
did you check the fuses behind the battery and have you added anything to your car lately
Old Jan 26, 2008 | 03:55 PM
Yea... i check all the fuses....and the newest thing i got for the car was the battery which is over a month old... I did read that a few people have had the same problem after driving in heavy rain... and i did drive though a ok size puddle.... some i doing a long re set of the ECU....
Old Jan 27, 2008 | 03:33 AM
OCG35's Avatar
Christine
Old Jan 28, 2008 | 09:46 PM
skix's Avatar
I have the same thing happen to me, but after an ECU reset it seems to working now. I use the touching Neg and Pos terminal method. Make sure you don't have after market stereo otherwise use other ways to reset ECU.
Old Jan 28, 2008 | 11:32 PM
Yea... Resetting the ECU worked the problem is gone. and everything is working Normal so far... still have to replace the tire then i really check the VDC system
