Engine cooling plate
Originally Posted by GFN-G35
haha honestly the air flow will not change hardly at all its for looks ppl say it helps air flow because it sells the product better.....
If you run an aftermarket intake without the snorkle (typically long ram) this won’t be an issue because you draw in air from down low.
If you have OEM, Stillen or JWT it's not a good idea to use this panel (IMO)
Originally Posted by OCG35
The intake snorkel is above the area that this panel blocks... so yes, the airflow does change - the intake won't get the air it normally does.
Jiggerjuice
Oct 5, 2015 02:33 PM
joedaddy1
Jul 28, 2015 02:58 PM
