UR Pulley question
Old Mar 16, 2008 | 02:24 PM
OG35Driver's Avatar
Angry UR Pulley question
I have the UR (underdriven) pulley set on my 03 G. Using Gates belts, but they seem to stretch a week after I adj them and the squeek on startup. The AC belt is stretched to the point I can no longer adj. Anyone else having this problem??? Any suggestions, or recommendations would be appreciated.
Old Mar 16, 2008 | 02:47 PM
sliderg35's Avatar
I've had the whole set on my car for over a year with the same belt. It did take a few adjustments initially to get it all set and not squeaking, but I haven't had to adjust it for over a year either.
Old Mar 16, 2008 | 05:20 PM
jonnylaw's Avatar
Squeeking will occur b/c of glazing of the belts by the soft aluminum. If they are really stretched or cracked, they probably need replacement
Old Mar 16, 2008 | 06:23 PM
G37Rider92649's Avatar
Gates belts? All i know is i used the Nissan belts that came with it when I had it, no problems. I don't know if it's gates you should be using, I might be wrong, as for the squeek, that is NORMAL, after I got it installed, they told me I might here squeaking within 1-2 weeks, come back or I can tighten it my self, it squeaked after 3 weeks, i just came back and they adjusted it, since then no problems.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
