Help me set a torque wrench?
Old Mar 22, 2008 | 11:11 PM
Heero's Avatar
Hello,
Does anyone know how to set a in-lb torque wrench that has the following numbers going down:
960
840
720
600
480
360
240
120
and it has a dial that consists of
0 8 6 4 2 0 8 6 4 2
I am installating the Motordyne Plenum Spacer and the required torque is 100 in-lbs. How do I set it properly?
I also tried torquing a few bolts and I do not hear any clicking noise or anything even when the bolt got really tight.
Sorry, I have never used a torque wrench. Google does not help either, and I couldn't search a topic that had instructions on this specific wrench. Thank you!
Johnny
Old Mar 23, 2008 | 12:19 AM
citymunky's Avatar
You need a new torque wrench, the lowest the setting on the one you have is 120 in-lbs, and the to install the spacer you NEED to have a range of 40 in-lbs to 100 in-lbs. If you try to use the one you have now you will snap the bolt in half.
Here watch this, they use Newton Meters, but its the same concept.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/187IHhDF9qE&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/187IHhDF9qE&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
