gas millage
Old Mar 26, 2008 | 01:22 PM
kavehdr1983's Avatar
gas millage
Hi I have a 2006 G35 COupe 6MT With Navi:
I am getting about 17 miles per gallon. and I drive about half high way /half road. I wanted to know if this was low or not? I bought the car used about 2 months ago. Is there something that could be old and needs changing that would improve this number? (fuel something....)
Thanks,
Kaveh.
Old Mar 26, 2008 | 02:12 PM
erdog's Avatar
I get anywhere between 17-19. My average is about 18 right now.
Old Mar 26, 2008 | 04:34 PM
Beebo's Avatar
you should be happy with your 17 im getting 13 and im stock iv looked at all the things it could be and everythings fine...
Old Mar 27, 2008 | 08:37 AM
k662's Avatar
Wow, 13? I just calculated my MPG yesterday when I filled up and I got 19.4 to the gallon. And this was the first week I've owned my car and drove it harder than I normally drive.
04 auto sedan.
Old Mar 27, 2008 | 08:45 AM
6MTzer's Avatar
I never calculate gas mileage, I don't want to know.
Am I the only one?
Old Mar 27, 2008 | 03:18 PM
ttrank's Avatar
Grocery getter
I average 16-17.
Old Mar 27, 2008 | 03:21 PM
BlueDevilBAMF's Avatar
City I get 15-17 (although on my latest tank I filled up on the slow setting - supposedly reducing air that gets pumped in on the high setting, which means the gallon reading on the pump is off if you fill up on the fast setting - and it appears I will definitely be topping 17 on this tank with no highway miles at all).
Strictly highway I get over 24mpg
Old Mar 29, 2008 | 01:08 AM
Beebo's Avatar
Originally Posted by ttrank
I average 16-17.
wow and your TT i thought it would be like 10
Old Mar 29, 2008 | 02:07 AM
princealyy's Avatar
I am avg'ing 19.2 on my current tank.. (and i have tested my computer and it is pretty accurate)
Old Mar 29, 2008 | 11:01 AM
Q45tech's Avatar
For about 50 years gasoline consumption in pounds per HP created has been relatively constant..............engines at best consume 0.45 pounds per HP hour. Super/turbo run richer and consume more at 0.55 pounds per HP hour.
We [engineers] just average it out to 0.50 pounds. How many HP does a car need to cruise for an hour at constant 55 mph speed say 25-30 or 12.5-15 pounds or 2 -2.5 gallons [22-27 mpg].
Reducing the HP created will immediately improve mpg.
Old Mar 29, 2008 | 11:09 AM
Da-G-SpoT's Avatar
It also depends on the gas station you go to. I have a Chevron next to my house and i ALWAYS fill up there. I always reset my trip counter on tank fills to see how i am doing in MPG. I average anywhere from 19-22 MPG on Chevron gas. I have filled up at Hess which was sort of an emergency and the results were just bad! My fills usually go at about 300-320 miles per fill. On hess gas i went 215 miles ! WTF. I didnt drive the car any different than i would of on a Chevron fill. Also, at that same Chevron i fill up at there are 2 pumps where i can get 300+ miles per fill constantly and the rest i could never get past 290 miles per fill. Again, this is confirmed and tested for the past year and a half! So far.....
Miles per fill:
Hess - 215-220 per fill
Amoco - 240-260 per fill
Shell - 225-240 per fill
Ugas - 270-280 per fill
I fill up everytime at about 16 gallons or so, which means that these averages were taken to a 16 gallon average fill and always on 93 octane.
Hope this helps out somehow. I would say to try out different gas stations and see what results your are getting. It took me a while to realize this and then when i started testing it i confirmed it. Just my .02 ^_^
Old Mar 29, 2008 | 11:13 AM
O HELLA OEM's Avatar
i only get 180-200 on a full tank of gas!..
Old Mar 29, 2008 | 02:02 PM
str8dum1's Avatar
ya i get ~ 16-18 mpg myself. dropped maybe 2-3 mpg since FI, esp on hwy cruise bc of the losses associated with the blower. needless to say, its not my daily driver.
