Car just shut down...
Old Apr 8, 2008 | 12:49 PM
KiddBrains's Avatar
I'm at a light and when I go to take off there is like no POWER at all, car is running but it wasn't getting power it seemed like, I put it in first and tried to take off and it would not do ****, Then the service engine soon light came on and the info popped up that I needed to find a dealership on the nav. screen. Can anyone tell me why that happened???
Old Apr 8, 2008 | 12:55 PM
Hi-TechG35's Avatar
Can you provide more detail?
Old Apr 8, 2008 | 12:59 PM
chilibowl's Avatar
Sounds like a limped out throttle body or MAF sensor.
Old Apr 8, 2008 | 02:31 PM
KiddBrains's Avatar
Can't really say more man, it was just dead, but I still had power. I pressed the gas and it slowly reved up but it took like forever for it to get up in high rpm. I then shut the car off and it was all back to normal except for Service engine soon light.
Old Apr 8, 2008 | 03:21 PM
G35captain's Avatar
It might be the brains making sure that you take the car in... Sounds crazy.
Old Apr 8, 2008 | 04:25 PM
KiddBrains's Avatar
Hey, that's a possibility, bc I've been on and off on this car for like a year, and I finally got me one...
Old Apr 9, 2008 | 02:03 AM
GhostfaceKillah's Avatar
the same exact thing happened to me twice this week!
i dont know if want to take it to the dealership though...
Old Apr 9, 2008 | 05:26 AM
meladh229's Avatar
same here man i had to pay the dealership 4000$ to fix it cuz i tried to fix it and they said i had to pay if i want it to be fixed. the car get all crazy and **** like it turns on and u it dont drive or like some times it wont turn off it was really bad like the comp with burned.... but i think that what happened to u..
Old Apr 9, 2008 | 10:41 AM
overmind's Avatar
weird i hope you get it straightened out!
Old Apr 18, 2008 | 02:23 AM
jhu1011's Avatar
try this https://g35driver.com/forums/g35-coupe-v35-2003-07/170218-help-engine-dies-right-after-starup.html
Old Apr 19, 2008 | 10:55 AM
hg35x's Avatar
My 2004 G35X did the same thing and then ran ok, but still had the check engine light (CEL?) on. The fault code was P2135 which I think is throttle position sensor. After further diagnosis the fault was traced to a faulty throttle PEDAL position sensor - the drive by wire lever assembly, not the TPS. It was replaced under warranty (I've got 9,400 miles on it). The model/part # for the complete lever assembly is 18002-am81d, $147.98. No problems since.
Before this happened I would punch the gas and it would pause for a second, then go. Now it has much better throttle response.
Old Apr 19, 2008 | 11:07 AM
O HELLA OEM's Avatar
this happened to me to..the dealer replaced the throttle body
chinee
Jun 10, 2024 07:48 PM
hdmark
Apr 29, 2019 04:31 PM
Joshua615
Aug 31, 2015 12:29 AM
apintojr
Jul 23, 2015 10:52 AM
brian_z
Jul 22, 2015 09:19 PM
