AirBag light on and flashing...
Old Apr 20, 2008 | 02:30 PM
Nin's Avatar
Nin
Hey all...
I recently purchased an '06 G35 Coupe 6MT in Ivory Pearl. It was involved in an accident and the steering wheel/drive side seat bag went off. They were both replaced with new ones and I was assuming there wouldn't be much else to it as far as the AirBag system goes.
The problem I'm having now is that there are NO CODES in the system, but the airbag light is still on. I've taken it to a dealership and they told me that they want me to replace the whole engine wiring harness ($1200 parts, $1500+ labour) which in my opinion seems a little farfetched.
I've tried the AirBag reset procedure to no avail. Anyone got any ideas?
Before everyone goes on about lecturing me on buying a salvage, please don't bother. I'm fully aware of the cons of buying salvage vehicles and am not concerned about them. I obviously would like all the AirBags to be working 100%.
Thanks in advance for any help!
Old Apr 25, 2008 | 01:50 PM
Nin's Avatar
Nin
ttt
Old Apr 25, 2008 | 04:34 PM
naughty240's Avatar
Are your sure they replaced everything? Some cars require new Bags, module, clock spring even seat belts. If you dont do everything you cannot clear the code. Look along the harness and see if you see anything that jumps out at you. Did you get any paper work with the car. In RI you need recipts or junkyard parts with VIN number the car came from.
Old Apr 11, 2009 | 03:03 PM
TonyF's Avatar
I'm having the same problem. After replacing the driver seat and curtain airbags, I have been confused as to what I'm supposed to do next in order to remove the airbag light. I called the dealer and they said I would have to take it in to have the airbag system reset, which should be $250. I called a g35 owner and he recomended a place that can have the system working properly again. So I'm in the process of getting that done.
If you have fixed the problem, got any advice for me?
Old Apr 13, 2009 | 08:08 PM
skottydzntkno's Avatar
i have the same problem
they attached the computer
reset the system and everything but stilll doesnt stop flashing
Old Apr 15, 2009 | 02:35 PM
ttrank's Avatar
Grocery getter
If no wires were cut I don't know why the harness would need replaced. The computer or one of the sensors may need replaced.
Old Apr 15, 2009 | 07:06 PM
GR6RR's Avatar
try the key trick!!!
turn the key to on ( do not crank), the light will stay lit, once the light goes off, turn the key to off,..
do this 4 times, and walla!
GR6RR's Avatar
hahaha I used google search for this, and it brought me back to the forums.. hahahaha..
Old Apr 15, 2009 | 08:16 PM
gomd3's Avatar
you probably need to replace the computer for the airbag system, The fsm mentions that when ever the airbags go off the module needs to be replaced. As far as I can tell you would need to make sure the seatbelts were also replaced because they go off along with the airbags. Good luck, try getting the codes from the system.
Old Apr 16, 2009 | 12:20 AM
wolf1's Avatar
+1, alot of cars/manufacturers are like this these days. Once anything in the SRS system is deployed the main control module needs to be replaced.
Old Jun 18, 2009 | 04:42 PM
TonyF's Avatar
Remove air bag light
So I had to replace my driver side seat and curtain air bags. Many people would tell me that the next step was to have the dealer hook up the computer to reset the air bag system. I found out that that wasn't true. All I had to do was replace the SRS air bag module that's located under the center console and the quarter pannel air bag sensor. After they were installed, the light just came off. I spent $280 on all four items which I purchased on ebay and craigslist.
The module you can get on ebay under $90. The dealer quoted my at $900. I saved a few grand by not taking it to the dealer.
Old Jun 18, 2009 | 04:45 PM
TonyF's Avatar
Sorry for the lack of information on the previous post. The dealer quoted me on all four parts (curtain & seat airbags, srs module, sensor) at about $2,500. I spent $280 and installed everything myself.
Luisgalvan33
Jul 19, 2018 08:16 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
leli_11
Aug 10, 2015 08:25 PM
