water
Old May 7, 2008 | 07:23 PM
delusionalv's Avatar
Question water
How often do you put in water/coolant ? You do use water in the radiator right ? lol
Old May 7, 2008 | 09:19 PM
RBull's Avatar
Rated M
^you shouldn't have to add any to the rad or overflow tank. There is a mix of coolant and antifreeze, usually around 50/50. If it is down there is a potential leak and the system may have to be bled after adding or replacement.
Old May 8, 2008 | 04:45 PM
yogi41's Avatar
if you do use water.. be sure to refill it with distilled water.. but the more water you use the more diluted your coolant becomes.. remember you want to keep it around at least 50% coolant:water.. but a few ounces shouldn't hurt..
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
alessandro
Oct 8, 2015 09:29 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
