g coupe shuts down
g coupe shuts down
wondering if anyone knows how sensitive the ecu is. could a abs light warning make the ecu shut down the car? was driving and stopped at a light and the cars rpm stumbled then came back to normal. i kept driving. A few feet later i lost throttle response then total power. tried restarting car, wouldn't start. disconnected battery to reset ecu. tried again, car started fine then cut off after a few seconds. did the same thing a couple of times.. used the pedal code to reset ecu, did not help. thats when i noticed the abs light coming on and off. know a few hours later car starts. any ideas?
had that same issue with my car. Car went into limp mode, then eventually shut down.
Turned out to be the Cam Position Sensor, which was a TSB. I say give infiniti a call so they can get it straight.
