Stillen Engine Torque Damper help!
Old Jun 30, 2008 | 06:15 PM
bluesaint's Avatar
So i'm following the directions and located the 3 holes on the frame rail, but only the small one is threaded, and the other two are simply holes with no ways for a bolt to go through. The instructions said there suppose to be some type of stock brackets down there, but I dont' have anything down there. Am I not seeing things correctly or is there some voodoo magic needed?
I can't possibly see how the stillen bracket can be bolted down when there's no thread in the 2 holes, while only the small 6mm does.
Old Jul 9, 2008 | 07:09 PM
Mr. Skyline's Avatar
I'm Guessing That You Have A Sedan? I Had The Same Problem, I Called Stillen, Because That's The Brand Of Damper I Used And The Informed Me That Only The Coupe Has Those 2 Rear Holes Threaded, And The Damper Is Not Made To Fit The Sedan So, They Said It Wouldn't Work, So I Proceeded To Weld The Bracket To The Frame And Finish The Install. It' Works Great And I've Had No Problems. SO, I Recomend Welding It, Just Do A Really Good Job Or It Won't Hold. I Can Send You Pics If You Like.
magnetism80
Feb 1, 2019 10:00 AM
Jnm07
Sep 5, 2015 01:16 AM
mikemf8
Sep 3, 2015 08:01 PM
Team STILLEN
Aug 10, 2015 08:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
