Help! Loss of power during high lateral G-force cornering on track
Old Jul 13, 2008 | 12:32 PM
Sagemark's Avatar
Originally Posted by DaveB
It seems to me that you're loosing fuel pressure and the most likely culprit is sloshing fuel in the tank. You really should be run with a lot more fuel because it fuel starvation could wreck the motor and also burn up the pump. Both my 96 Maxima and 94 Z28 would cut out power when taking them into really hard manuvers with 1/8 tank of fuel. The G fuel tanks don't have baffles nor are designed for high G loads. You need to run more fuel to compensate for this.
That's exactly what I fear is the problem, but with the problem showing up at 5/8ths of a tank, keeping it full isn't the most practical solution at the track although I suppose it *is* possible. I wonder if there are any bolt on baffling solutions for the G35 sedan tank...
Old Jul 13, 2008 | 05:01 PM
OCG35's Avatar
are you applying brake and throttle at same simultaneously at any time in you cornering? Applying both on my car cuts power briefly – I’ve tried to get a mod to trick the ECU into not recognizing both are applied… it was on a list for a particular vendor/manufacturer but I don’t think it’s a priority right now…
Old Jul 13, 2008 | 05:53 PM
Sagemark's Avatar
No, I was definitely not applying both at the same time.
Old Jul 15, 2008 | 04:16 PM
Canadian's Avatar
Canada, eh?
Did you get a chance to look in the tank yet?
Old Jul 15, 2008 | 04:23 PM
Klubbheads's Avatar
What kind of turn is it. Is it a constant high speed constant turn or a tight one?
The only explanation that comes to my mind is PulsePlugs considering recent misfortunes that people have had with them. Try getting rid of those on ur next event before getting into deeper details.
Old Jul 15, 2008 | 10:15 PM
Zoom750's Avatar
http://www.my350z.com/forum/showthread.php?t=366374
Old Jul 16, 2008 | 02:31 PM
Sagemark's Avatar
Not yet, maybe this weekend...
Old Jul 16, 2008 | 02:33 PM
Sagemark's Avatar
I hadn't heard of issues with Pulseplugs... and I don't find anything when I search for any threads here... Can you provide a link to what you are referring to?
Old Jul 16, 2008 | 02:39 PM
Klubbheads's Avatar
here: several members having major issues with these plugs
https://g35driver.com/forums/tuner-dyno/231707-pulstar-plugs-junk.html
Old Jul 16, 2008 | 02:49 PM
OCG35's Avatar
I've seen several... search here and on my350Z...
Old Jul 16, 2008 | 02:51 PM
Sagemark's Avatar
It was initially and primarily in the tightest corners. It progressively worsened occuring in most corners as I emptied the tank.
I am fairly certain that it is just a lack of baffling and that it is a design issue with the car.
There have been no responses from anyone else about their experience when tracking the sedan, either confirming they've had the problem or not...
Again, this has never occurred to me on the street but was a real problem on the track where I was pulling higher lateral forces than I ever do on the street. Maybe I might pull a similar force once in a while on a highway ramp but it hasn't manifested the problem. I think it has to do with back and forth high lateral force cornering sloshing the contents of the tank wildly to one side or the other in a way that just doesn't happen on the street.
Old Jul 16, 2008 | 03:08 PM
Sagemark's Avatar
https://g35driver.com/forums/showthread.php?t=231707
Well that's scary enough for me to pull them out! Eeek!
Old Nov 20, 2008 | 02:26 AM
Dan_K's Avatar
Common issue with G35/350z's. I guess it the way the fuel system is designed, but on tight corners where you have less than 1/4th fuel, the pump will struggle to keep the pressure constant due to low level and therefore you engine will not get enough fuel. If this happens, the engine goes into limp mode. I've had this happen at several track events.
Old Nov 20, 2008 | 01:47 PM
GreenGoblin's Avatar
The goblin resurrection
^ exactly what I figured it would be
Old Feb 18, 2021 | 10:52 AM
  #30
Eric23's Avatar
03 sedan
Cornering
Has anyone here ever had fueling problems/ loss of power while tracking your sedan??
i have experienced this as well i was hoping to find an answer but im thinking do to the shape o the tank in hard right corners all the fuel shifts to the other side of the tank and it gets air for just a moment i know its not my VDC because i have disconnected my YAW sensor so it can not kick in
