1 broken bolt on lower plenum, okay to drive for now?
Old Jul 11, 2008 | 07:10 PM
YoungGblood's Avatar
hey guys, I just installed my new 5/16 thermal spacer. I was using a torque wrench and it didnt click at the setting so I broke one of the 8 lower plenum bolts.( I already ordered a new one but it's not coming in until 2 days later). What I wanted to know is, is it okay to drive on it with a missing bolt? the others are torqued to setting, but Im missing a bolt. I've already started the engine and it seems like all is well, but it is my only daily driver, so I wanted to know if it was okay to drive like that for a day or two until the bolt comes in?
Old Jul 11, 2008 | 08:10 PM
jjyellow's Avatar
should be ok as long as it doesnt start to leak air, but get it fixed asap
Old Jul 12, 2008 | 12:04 AM
thanks for the info, Ill take it ez til then. I should be getting the bolt, hopefully, monday. At the lastest, tuesday and Ill put it in asap and I'll have my 4 day spacer project complete!
Old Jul 12, 2008 | 01:21 AM
richie's Avatar
hopefully its just a broken bolt...similar thing happened to me but the threads on the lower collector were jacked up too and needed to be re-threaded
Old Jul 12, 2008 | 04:20 PM
I put a bolt back in to spot numer one (this is where the bolt broke according to motordynes torque sequence) and it threaded just fine and tightened back up. I left number, i believe it's 4, empty. It seems as if the threading is fine. But yeah, that sucks. Re-threading.
Old Jul 12, 2008 | 05:21 PM
terps's Avatar
try a longer bolt, same thing happened when i installed the aam spacer, and the bolts supplied only hit like a 1/3 of the treads. only hand tighten it and it should be good. ive been told that if one strips its fine due to there being like 12 or something
Old Sep 13, 2008 | 12:04 PM
cicada06's Avatar
I too just broke a bolt can i order a new one from the dealer?
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
wuppiedog
Aug 7, 2015 11:16 AM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
