Changing plugs?
Old Jul 11, 2005 | 04:19 PM
dklau33's Avatar
Originally Posted by papagz
i just spoke to my mechanic today about changing the plugs. he said that it wont make any difference unless the car is running hot, or in hot temperatures. if your going FI then its a must b/c of the extra heat, but if your running mostly bolt ons, not gonna make a difference. he actually said it may even run worse...
Originally Posted by dklau33
The only reason to go with a colder plug is because your engine is creating significantly hotter cylinder-head or combustion chamber temperatures compared to stock. Extensive engine mods like forced induction or heavy NA engine work with high compression ratios will generate that added heat. So colder plugs are needed in those situations in order to draw away the added heat and regulate the temperature of the spark plugs firing tip. So don't think that just by adding colder plugs to a stock or mildly moded car will produce improvements. In fact if your plugs are too "cold" you will end up fouling your plugs in a much shorter period of time because the plugs aren't hot enough to burn off the carbon deposits.
Here's a pretty good article on spark plugs.
Click Here
Old Jul 11, 2005 | 04:25 PM
papagz's Avatar
ok wow, i def knew that...i swear im not retarted
Old Feb 13, 2007 | 07:48 AM
My'03G35's Avatar
great write up and this job doesn't take much effort and took all of 35 mins reading the write up ... and the car has a little more pep in its step
Old Feb 13, 2007 | 03:27 PM
QuadCam's Avatar
thanks.
I think I have changed my plugs a bunch since I wrote the instructions.
Last time, it took me just under an hour including pullinng all the plugs, regapping them, and then reinstalling them
brane123
Interior
Aug 23, 2015 06:55 AM
JoeMac
Aug 20, 2015 10:17 AM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
