Oil Cooler O-Ring???
Old Jan 6, 2012 | 08:25 AM
  #31
obsdnoblivion's Avatar
Originally Posted by Michael Joneser
Did mine yesterday, it was a 22mm. I recommend using a 6 point socket or wrench not a 12 point because the head is very short and could strip. I don't know what the torque is suppose to be so I just snugged it up well.
Make sure you keep the new o-ring and inside the housing and bolt clean from debris, I cleaned the inside of my 22mm socket before using it to remove the cooler.
The diagram posted near the beginning of the thread said 36 ft-lb. I know I put more torque on it than that. I couldn't remember the spec and I didn't have access to the diagram when I put it in yesterday. Michael Joneser, how big a sin do you think it is it to over-torque it? And you other dudes? Is that so bad?
Old Mar 11, 2015 | 08:09 PM
  #32
Mustang5L5's Avatar
Are you guys replacing the Oil Pressure relief valve as well?
FSM states to replace it any time the oil cooler is off.
P/N 15241-43UOA
Old Mar 12, 2015 | 08:21 AM
  #33
I didn't.
Old Mar 12, 2015 | 08:41 AM
  #34
Frankieg35's Avatar
I think i have to do mine, i noticed a small leak when i changed my oil, i think I will do it on my next oil change which will be soon..
Old Feb 19, 2016 | 12:14 AM
  #35
React's Avatar
Just changed mine out it was pretty straight forward. Going to replace my valve covers next to have that peace of mind (not leaking).
Old Feb 22, 2016 | 06:05 PM
  #36
Infinite1's Avatar
20 Year Member
Just changed out my o-ring pretty simple. seemed to have sprung a leak in the general area so I hope this fixed that issue.
Regarding the relief valve....how is it removed? I tried using some needle nose pliers but couldn't grip it. Does anyone have any input on how to change this? I'll likely do this during the next oil change.
Old Feb 23, 2016 | 12:07 PM
  #37
Mustang5L5's Avatar
I never changed mine out. I tried a few methods, including threading a bolt inside the vale to pull it out but it didn't quite work for me. Left it in place and just replaced the O-ring. Was a pretty straightforward job although slightly diferent in the AWD cars. Been leak free ever since.
Still have the relief valve in my tool-box, although I don't think i'll make an attempt to replace it. While an easy job overall, I'm too lazy to take it apart again
Old Feb 23, 2016 | 02:05 PM
  #38
Infinite1's Avatar
20 Year Member
Thanks for the reply. Yeah I am in the same frame of mind. I said F-it.. My 30 min oil change turned into an hour b/c I was dicking around trying to figure it out. LOL.
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
dseet
Oct 11, 2015 12:40 AM
9tray turbo
Sep 29, 2015 10:22 PM
