Low-End HP Question.
Old Aug 10, 2008 | 05:07 PM
mpspeer's Avatar
Patrick
Quick question here. From what I have been reading, most upgrades seem to be more productive at producing HP at higher RPM's (sometimes losing some hp/tq at lower RPM's).
Since I am not flooring it around town, which upgrades will help me out in the lower end of the RMP band? Not looking to go FI BTW.
P.S. Look at my Sig to see my current mods.
Thanks,
Patrick
Old Aug 10, 2008 | 06:33 PM
mIKE's Avatar
4-2-1 headers, different size spacer.
Not cheap for the headers, and you''ll lose top end. Headers just shift the power band.
Old Aug 10, 2008 | 06:49 PM
OCG35's Avatar
shorter rear end gears... 3.692 (3.7) FD - OEM Nissan. You will be happy, trust me!
Old Aug 10, 2008 | 10:04 PM
DaveB's Avatar
Get rid of the intake and possibly the exhaust and add gears like OCG35 said. Keep in mind you'll loose cruise control though and you're MPGs will be impacted. I had the Borla TD and it definitely hurt the lowend punch of the car. The car simply didn't leave the line hard, even with my typical brake-stall 2,400rpm launch.
Old Aug 10, 2008 | 10:07 PM
dev1983's Avatar
how much would the gears cost?
Old Aug 10, 2008 | 10:59 PM
mpspeer's Avatar
Patrick
Ehh, Cruise control is a big luxury to me lol... Is there anything else I can ADD to help with me low-end rpm problem?
I like the mods I have now, is getting rid of them the only option?
Old Aug 10, 2008 | 11:25 PM
OCG35's Avatar
cruise control remains with 3.7
Old Aug 10, 2008 | 11:26 PM
OCG35's Avatar
about $450 plus install
Old Aug 10, 2008 | 11:28 PM
OCG35's Avatar
high flow cats
but I think you'd be very happy with 3.692 ring and pinion gears.
Or do both like I did
Old Aug 11, 2008 | 09:59 AM
mpspeer's Avatar
Patrick
Originally Posted by OCG35
high flow cats
Two things: Is "3.692" to same as "3.7" therefore my cruise control WILL remain? Where do I purchase this?
Also, Will resonated TP's do the same thing as the HFC, or will the HFC's do something a little different...other than making my car legal of course.
Old Aug 11, 2008 | 10:27 AM
Texasscout's Avatar
A positive displacement supercharger like a Stillen will give you the low end grunt you want. $$$$$$
Old Aug 11, 2008 | 11:14 AM
Klubbheads's Avatar
get rid of the pop charger. It makes the car feel like a chocking dog trying to pull the leash till u get up to speeds above 80mph.
Old Aug 11, 2008 | 11:19 AM
mpspeer's Avatar
Patrick
and replace it with...
Old Aug 11, 2008 | 11:23 AM
Klubbheads's Avatar
STOCK! Or if u really have to have one go with Stillen.
Old Aug 11, 2008 | 12:04 PM
DaveB's Avatar
Not on an 03 or early 04 car. You have an 04.5 and for whatever reason, changing the gearing works without impacting the use of CC. I've reasearched the heck out of this and pretty much if you plan to run gears in 03/04, you can kiss the use CC good bye if you want to cruise at speeds over 70mph. It won't work if you have the CC on and then exceed ~70mph. And when you exceed 70mph with the CC engaged, it won't reengage until you restart the car.
