A/F Gauge or Monitor
Old May 11, 2004 | 11:09 AM
SixFive's Avatar
Anyone monitor thier A/F ratio with a guage or other monitor. I have no Nav and would like to be able to do this without a laptop. Nitro kits come with an AF guage right - cant we just use on of those. I would imagine it piggbacks the MAF sensor somehow?? Am i out there or is this easy?
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Injen CAI
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk ex-3500 Tweeter Upgrade/Shock Sensor/H-Liner Under Hood
Old May 11, 2004 | 03:29 PM
InfinitiTech's Avatar
Re: A/F Gauge or Monitor
Your air fuel ratio is measured at the tailpipe. Infiniti uses what they call an alpha reading, 100% is where you want it to read, lower means richer and higher would mean leaner. and it can be monitored with our scanner. Why would you want this reading?
Infiniti Gearhead
Old May 11, 2004 | 04:58 PM
350gtboi's Avatar
you can use a simple A/F gauge from autometer but those are usually not very accurate since the reading changes based on the temp of the stock o2 sensor.. if you want the best accurate reading get the new aem wideband 02 Sensor with a Gauge..
http://www.aempower.com/product_ems.asp
Old May 11, 2004 | 07:40 PM
jdove's Avatar
If you ever intend to use FI this setup seems to be the best value. Both display and logging capablity. The only unit I've seen than can log "EGT" along with RPM, Boot , A/F. You really should add a bung just before one of the CATS for this setup . Anything tapped post CAT is worthless for tuning purposes.
http://www.zeitronix.com/Products/zt2/zt2.htm,
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
JustinMKN1
Sep 18, 2015 03:40 PM
