Dynamat in progress, part 1 (w/ pics)
Old May 19, 2004 | 04:03 PM
cryhavok's Avatar
Hey all,
I got my dynamat in a few days ago, and thought today would be a good day to start the process. I have never used dynamat before, so today was the first time applying it.
<img src=http://img38.photobucket.com/albums/v117/cryhavok/dynamat/DSCF0004.jpg>
I got this "bulk" kit (dynamat extreme) off ebay for about $90 plus shipping. Contains 36 sq. feet in the form of 9 sheets
I used the DIY rear seat removal posted by "nycg35" found here: https://g35driver.com/forums/showfla...&part=all&vc=1
Great write up!
Back to the topic. I found it easiest to make a template out of paper and then transfer it to the dynamat for cutting.
Here is what the original back looks:
<img src=http://img38.photobucket.com/albums/v117/cryhavok/dynamat/DSCF0005.jpg>
Notice the olive drab mat. It is not glued down or anything, rather just sitting there. I don't know how good it does at dampening the sound.
Here is a pic of the first sheet I applied.
<img src=http://img38.photobucket.com/albums/v117/cryhavok/dynamat/DSCF0006.jpg>
The sheets are rather easy to apply. Once the template is made, simply start at a corner and slowly press into the crevases and such. I used a 1" wallpaper wooden roller to help smooth everything out and make sure there is a tight bond between the dynamat and the metal.
I cut a special piece to cover the lids, rather than just leaving it solid. No need to do anything if they have to be removed.
I finished the other side and used some of the scraps to fill in some of the other areas.
<img src=http://img38.photobucket.com/albums/v117/cryhavok/dynamat/DSCF0007.jpg>
This is not a quick project, nor is it relaxing work. :P Tomorrow I will work and remove the side panels to get to the wheel wells, where I will put 2 layers of dynamat. Then I'll move up to the front of the car and do under the floormats/front wheel wells. Leftovers will probably be put in the trunk area.
With these layers, there is a slight decrease in road noise. The real "hot" spots are above the wheel wells.
Old May 19, 2004 | 05:04 PM
g35mt's Avatar
Re: Dynamat in progress, part 1 (w/ pics)
Nice...i will do that soon when it arrive. Also, are you planning to do the rear side panel? If you do, please post pic..so that i can have an idea. thanks.
g35mt
Old May 19, 2004 | 05:37 PM
dyenboy's Avatar
Registered
o very nice..I totally forgot about doing those..
Are u gonna do the whole car or jus the trunk?
GGG Member Signup
Old May 19, 2004 | 06:36 PM
quikrocket's Avatar
Cry,
Maybe I missed it, but why did you put the Dynamat in? Did you swap out your exhaust or install a mega-stereo?
Q
Old May 19, 2004 | 06:55 PM
Meatshackle's Avatar
Deep Sea Moderator
How much did that box weigh? Just wondering how much added weight we're talking .
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old May 19, 2004 | 07:41 PM
cryhavok's Avatar
g35mt,
I'm planning on doing the rear wheel wells, which require removing the rear panels to get to the front of the wells. The back of them can be accessed through the trunk. I will take pics of before/after all the areas that I do.
dyenboy,
Tomorrow I'm going to focus on doing the wheel wells.
quikrocket,
I put the dynamat in inorder to get rid of the road (tire) noise. Our cars aren't exactly the quietest of the bunch inside the cabin, so hopefully I can get rid of some of the noise. It should also help clarity of the stock system a little (less sound the music has to "overcome")
TrentaCinque,
The box weighs 15 lbs, read from the shipping sticker. I'm not worried about the weight gains. For me, a more peaceful ride (when I want it, I normally drive windows down, but there are always those times when taking a nice girl out and quiet is in need) give me greater satisfaction than having 15 less pounds.
Old May 19, 2004 | 08:12 PM
Deep Sea Moderator
I agree with you there. 15lbs isn't that much added weight. How much of the car do you think you'll be able to do with what came in that box?
Russ
Black 6MT Coupe
Jax, FL
Old May 20, 2004 | 12:43 AM
cryhavok's Avatar
Well, It took 2 sheets to do all of under the seats. I figure another 3 sheet total to do both front wheel wells/under the carpet of the passenger/driver. The package contains 9 sheets total. Probably a sheet for each rear wheel well.
So that leaves me 2 sheets for doubling up on the 4 wheel wells.
Old May 20, 2004 | 11:56 AM
zazaracing's Avatar
Team Transport Member
That stuff is awesome but man Its hell to put on and weighs so much but indeed the sound is worth it if you wanna spend the money! aint too cheap....
Aj
Old May 20, 2004 | 02:27 PM
BigRon's Avatar
I see you're as **** about it as I was with my '97 Mits. GSX! I went for complete coverage as well. lol It did help on the sound a great deal... ...considering the Mits. had NO sound insulation material in the cargo area (besides the carpet & mat).
It is extremely heavy stuff, but as was mentioned you're not adding a ton of weight. And look at it this way: Besides the sound insulation, you're improving the weight distribution some. lol
Future G35C Owner... ...Never too soon to think about modifications!!
Old May 20, 2004 | 05:06 PM
cryhavok's Avatar
I just finished typing up my update. Click this link to read it:
http://forums.freshalloy.com/ubbthre...1#Post67759010
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
9tray turbo
Sep 29, 2015 10:22 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
