need help 04 g35 missfire
The misfire is due to a loose wire. The code should tell you which wire it is. Redo the ignition wire connectors on that cylinder. I had a misfire code for a while and had to do that to fix it. It is NOT "normal". Don't put up with it - fix it.
hey i checked the code but it doesnt say which one just says random miss fire do you know another way to check and you said a loose wire you talking about a ground or at the emange thanks for your help
i just put new spark plugs in and have stock ecu with emange blue
what gear were you in? If you were in a higher gear and lower rpms, there might not be enough fuel to support it. In that case you need larger injectors or a fuel system upgrade. If your thinking of larger injectors, your looking at a reflash of the stock ecu or osiris etc. What did your tuner say about this?
laksjd84
Jul 24, 2015 05:12 PM
