Need An Expert On Interlock!
Old Nov 5, 2008 | 05:58 PM
SlavicG35's Avatar
Exclamation Need An Expert On Interlock!
Hello all. I am back with the same problem, but now I have a code. P1730! ""Problem still is the car going into limp mode randomly. Fixed by shutting car off and on a couple of times. Then returns. Sometimes 2 days.. Sometimes 2 mins."" This code points to having a problem with the interlock (shifter/Tranny) First off.. I need to know what where and why about "interlock".I dont know anything about "interlock". Then I need to know if anyone has had this issue. I've tried the forums. Nothing that I can find. Thank you for any input. I am desperate.
Old Nov 6, 2008 | 08:41 AM
rcdash's Avatar
Is this a completely stock G35? Model, year? No info = no help.
Old Nov 6, 2008 | 09:16 AM
fbpem1's Avatar
year?
coupe?
sedan?
i need this info to help you out haha. differant wiring diagrams for differant models.
if its a sedan is it awd? rwd?
Old Nov 7, 2008 | 11:16 AM
Q45tech's Avatar
All AT vehicles have interlock to prohibit cranking in gear, only allow in park or neutral. Usually a simple rotary switch on transmission or within gear shift assembly.
Obviously you haven't spent a week reading the Factory Service Manual which is free to download from many sites:
http://www.phatg20.net/component/opt...c,select/id,6/
Jiggerjuice
Oct 5, 2015 02:33 PM
dcsbh1
Oct 1, 2015 03:15 PM
DRG35R
Sep 16, 2015 05:33 AM
