How much coolant do I need for drain/refill?
Old Jan 9, 2009 | 12:04 AM
mikeee2's Avatar
Hi all,
I plan to pick up a few 1 gallon jug of prestone 50/50 to do the coolant drain/refill once the weather gets a little warmer. From the manual it said the car has 9.25 qt with reservior tank. 1 gallon is equal to 4 quarts so the procedure should require over 2 gallons but less than 3. Just wanted to double check with you experts. My G is 4 yrs old with 29k miles.
Sorry...but couple more questions. Where do I dispose anti-freeze? Can I just bring it to the mechanic shops like oil?
I also need to purchase two washers (for drain plug and air relief plug). I have the part #. Do you guys go to Infiniti to buy them or Nissan? Or it shouldn't matter at all?
Thanks...
Old Jan 9, 2009 | 10:46 PM
bythabay's Avatar
Originally Posted by mikeee2
Hi all,
Thanks...
I would HIGHLY recommend using the OEM coolant since it is specifically formulated to work with the materials our cooling system / water pump is comprised of. Pick up one gallon of distilled water and one gallon of coolant, you will have about .5 gallons left when you are done.
The part # for the air relief plug and radiator drain plug o-rings is:
INF 21481-89900
approx $2.25 each + tax retail cost
Old Jan 9, 2009 | 11:33 PM
mikeee2's Avatar
INF 21481-89900
Interesting. So if it only requires 1.5 gallon (6 quart) that means it doesn't drain everything?
Old Jan 9, 2009 | 11:40 PM
bythabay's Avatar
Yes, that' correct. Coolant will still remain in the hoses, engine block, etc.
Old Jan 9, 2009 | 11:51 PM
mikeee2's Avatar
Thanks for all your replies (including replies from the DIY thread).
Old Jan 10, 2009 | 02:21 PM
UMBG35's Avatar
yeah, definitely get OEM solution...expensive but worth it.
Old Jan 10, 2009 | 06:27 PM
mikeee2's Avatar
Hmmm...I really don't mind paying the more expensive OEM coolant. Just seems like a bit of a hassle having to buy distilled water and an extra jug to mix in the fluids. Some people on this forum also uses prestone and said it's fine. Well, I am not doing it yet so I'll consider the OEM coolant as well.
Old Jan 10, 2009 | 06:34 PM
bythabay's Avatar
Don't be lazy when it comes to car work; do it right the first time. I think that's the most important thing I could tell anyone.
Old Jan 10, 2009 | 07:14 PM
mikeee2's Avatar
Haha...good point Unfortunately, for the last 4 yrs I've been pouring Prestone in everytime it goes a little under Max. I would think by now, there's a good quart or two of Prestone mixed in.
Old Jan 10, 2009 | 07:21 PM
bythabay's Avatar
I think a more important issue now is why you are loosing coolant.. do you have a leak somewhere? The level is not supposed to change much, or even at all.
Old Jan 10, 2009 | 07:28 PM
mikeee2's Avatar
Really? all the cars I've own in the past are like that. A quart or two may be a little exaggerated over 4 yrs but usually every 3 months or so, all my car's coolant level would go down about 1/4 inch or so under Max.
I always think it's normal that it consumes coolant like that. My G was doing that from day 1. I have a used Sentra that I bought last year and I do a similar Prestone top off every 3 months or so. Technically, it's only a little under Max and I don't really have to top it off but I've always been doing it.
Old Jan 10, 2009 | 07:30 PM
bythabay's Avatar
My vehicles don't consume any coolant whatsoever. I have 2 Toyotas and this Nissan (G35). The toyotas both have over 300k miles; the G has 70k. Might want to make sure there are no leaks as my coolant level does not change.
Old Jan 10, 2009 | 07:35 PM
mikeee2's Avatar
Sorry, I edited the previous post a little after you posted this reply. I really don't see a leak, otherwise I would see green stuff on the garage floor or the under body plastic guard.
I've been topping off coolant on all my cars in the past / present.
1990 M/T Eagle Talon Tsi
1992 M/T Honda Accord Ex
2001 A/T Nissan Sentra Gxe
2005 A/T Infiniti G35x
Old Jan 10, 2009 | 07:45 PM
bythabay's Avatar
It might have something to do with your climate. I know New York can be very hot.
Old Jan 10, 2009 | 07:47 PM
mikeee2's Avatar
Hmmm...very possible. We get extreme heat and extreme cold. 4 season weather. Maybe some other Northeastern people can chime in.
Since you are in West coast, you probably get similar weather year round.
