Side Marker Blinking DIY Mistake
Old Jun 12, 2004 | 06:38 PM
MyGUnit's Avatar
I just did the side blinker mod on my coupe. It was really simple... The DIY says that the purple/white wire needs to be cut on the passenger side. what i did on both sides is splice into the green/white wire. It could be because I have an '04, but i just connected the black wire from the side marker to the green white coming off of the blinker, and abracadabra, my clear corners blink now
PM me for more info. I didn't take any pictures. Sorry
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old Jun 12, 2004 | 08:08 PM
GRider35c's Avatar
Re: Side Marker Blinking DIY Mistake
i have the exact same car as you (minus the navi) and followed the DIY guide to a T, and mines works fine...
green wire for one side, and purple wire for the other
04/BO/G/aero/splash/prem/perf/cc/22%tint
Old Jun 12, 2004 | 11:45 PM
MyGUnit's Avatar
hmm.weird...did u cut the black wire on the clear corner on both sides as well?
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Clear Corners
Pop Charger
Z-Tube
Old Jun 12, 2004 | 11:54 PM
GRider35c's Avatar
yeah... it works fine
Old Jun 13, 2004 | 10:24 AM
MyGUnit's Avatar
well, as long as both of ours works fine...more power to us ! haha
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Clear Corners
Pop Charger
Z-Tube
Old Jun 13, 2004 | 02:42 PM
korz's Avatar
How did you guys get at the wiring? I searched for the DYI but couldn't find it on this site.
korz
04 Diamond Graphite Sedan - 5AT / sunroof /
Deep Cut Rubber Floor Mats (Chicago Winters) /
PREORDER WINDOWS-UP MOD
Old Jun 13, 2004 | 03:20 PM
redwillow's Avatar
20 Year Member
you just need to remove the front section of the wheel well liner. It is held on by some plastic clips, a screw, and about 8 bolts + 2 more clips under the bumper.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
Old Jun 13, 2004 | 05:46 PM
dave's Avatar
Instructions are available here.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jun 14, 2004 | 02:16 PM
korz's Avatar
Thank you guys. This mod is complete. Only took 30 minutes.
Ron.
Old Jun 14, 2004 | 03:04 PM
GRider35c's Avatar
ummmmm, you must be superman!
it took me about 2 hours...
did you have access to a lift??
Old Jun 16, 2004 | 11:32 AM
korz's Avatar
Naw G ... I just hand jacked the car and poped the center plugs on the plastic retainers, 5 bottom 10mm, top phillips screw; cut the black wire 1/2" from the top end; crimp-clamped the green/wht & purple/white to each sides black, taped-up and snaped it all together again.
Oh yeah, my wife was due back any minute.
Ron.
WINDOWS-UP MOD by OEM remote
Old Jun 16, 2004 | 12:31 PM
GRider35c's Avatar
ok so you didnt remove the wheels... nice show!
Old Jun 17, 2004 | 10:08 AM
korz's Avatar
did too
WINDOWS-UP MOD by OEM remote / Side-marker blinker
Old Jun 19, 2004 | 01:12 PM
khsonic03's Avatar
Actually, there is two stages to the wire. So either way is good. I did the green/white wire on mine on both sides, but you can use the purple wire as well. It was a while ago, but I am pretty sure the purple wire goes into a wiring harness, then comes out as a green/white wire.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old Jun 20, 2004 | 12:36 AM
Sukairain's Avatar
Awesome mod, but I wish the blinkers would work in day time, too. Seems like the side marker blinker only works when side markers are turned on.
btw: I did the purple/greem wires~ Works fine. Took an hour, I didn't remove the wheels.
