What are the consequences of undertightening your belts?
Old Feb 4, 2009 | 12:40 PM
nuttyprof's Avatar
And I dont mean the effect of your pants falling off.
I'm talking about your pulley belts. I just changed them out, and I'm not sure if I overtightened. I had a major squeal problem before, but now its gone. For good I hope.
Old Feb 4, 2009 | 01:14 PM
gunluvS14's Avatar
worst case scenario the belts pop off during shift or sudden jerk (i.e. AC cuts on), or it would just squeal.
but since its not squealing now, you are fine.
Old Feb 4, 2009 | 01:44 PM
GreenGoblin's Avatar
The goblin resurrection
A tight belt is a quite belt. If you crank on it like an animal the belt could possibly brake, due to the added stress
Old Feb 4, 2009 | 08:48 PM
nuttyprof's Avatar
OOPS, I meant to say "Overtighten."
I suppose it would cause a lack of power (voltage) or possible breakage. Hope I dont get any of that! Hmm. if anyone has a belt tension guage around Arcadia, CA.....
Old Feb 5, 2009 | 05:27 AM
wingsprint410's Avatar
Over tighten?
If you over tighten the belts, they will fail quicker due additional heat from friction. You also will run the risk of putting addtional stress on the bearings in the A/C compressor, alternator and the power steering water pumps.
Follow the FSM specifications.
Old Feb 16, 2009 | 07:06 AM
Jtcurly's Avatar
What about camshaft drive. Is there any service that needs to be done to my 03 coupe with 95k?
Old Feb 16, 2009 | 12:37 PM
nuttyprof's Avatar
alrighty. so this is what I've noticed.
After changing and tightening my belts (probably overly so), my radio takes longer to turn on. I have an aftermarket headunit, amp, as well as speakers. I think it takes longer for the amp to get enough power to start powering the speakers.
Basically, what this means is that the strain on my power system is a lot harder. Just for future reference.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
cmesidewayz
Sep 29, 2015 09:28 PM
TNRocker
Sep 21, 2015 08:36 AM
reaper76
Sep 20, 2015 11:59 AM
