Running little hot
Old Feb 19, 2009 | 11:00 AM
Nicram's Avatar
Originally Posted by Infiniti Chica
I'll try not to be repetitive since you've gotten good advice so far. I'd start with the thermostat, especially since you describe 2 temps on the top and bottom hoses. Thermostats are usually a 2 bolt removal- it seems the most likely first place to look since you have coolant in the car. Secondly, if that doesn't fix it, move up one step and look at a faulty sensor possibility-- a bad sensor can result in your engine running rich and unstable cabin and engine temps. If that doesn't fix it, look at the radiator core-- is it blocked. The next step is examining the water pump-- is it going bad, Finally, and this one requires you swallow first, check for exhaust in the cooling system to make sure it's not a blown head gasket.
So you basically move from least expensive and simplest to most expensive and complicated. Good Luck.
Ok I am checking the thermostat today.
The correct way to check the thermostat is to boil it and watch it if it opens correct?
Wouldn't the bad sensor show up on the OBD bc the only code I have is the p0113 which i do not think would cause engine running that much warmer. By Sensor you mean temperature sensor or other ones ? ( which ones )
Old Feb 19, 2009 | 06:28 PM
Nicram's Avatar
In the repair manual it says that both hoses ( upper and lower ) should be hot to touch. Will check and get back to you guys.
Old Mar 7, 2009 | 09:08 PM
Nicram's Avatar
Bump tp the top!!!!
I changed the thermostat and no effect. Still running tiny bit over. How do I check the Gauge or the temp sensor?
Old Mar 8, 2009 | 01:53 PM
geronimomoe's Avatar
Clogged radiator?
Old Mar 10, 2009 | 05:42 PM
Nicram's Avatar
Originally Posted by geronimomoe
Clogged radiator?
NOw how do i check this??
Old Mar 13, 2009 | 10:45 AM
Nicram's Avatar
Anyone how to check for clogged radiator?
Old May 1, 2009 | 11:15 PM
Nicram's Avatar
Hey guys! I finally did the E swap, I bought a kit on ebay for $80 and pronto! Kit includes two 15 or 16 inch fans ( cant remember which one ) mechanical thermostat all the wiring and fuses. Work time was around 5 hours, works great turns on around 175 degrees. I took some photos I will post DIY late on. Thanks for help!
G35Rican
Jul 31, 2024 01:37 AM
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
