Cleaned Throttle Body, now SES Light On...
Old Apr 13, 2009 | 04:24 PM
nibble's Avatar
So I cleaned out my throttle body yesterday since it was pretty dirty. After putting it back together I attempted the Idle Air Volume Learning procedure as described in the factory service manual that I have in PDF form. I don't think I did it right, but after starting the car and running it for a while it all seemed fine, I was idling around 800 RPM. Maybe several hours later my Service Engine Soon light came up and I noticed I was idling around 900 RPM. This morning I attempted the Idle Air Volume Learning procedure again and I think I nailed it since I'm now idling at the recommended 650 RPM (+/- 50 RPM). However my Service Engine Soon light is still on. My car seems fine, I don't notice anything wrong with it. I was just wondering if there's an easy way to read the code thats causing the light to turn on. I don't have a consult-II or anything like that. But I know on my dad's '02 Dodge Dakota you turn the ignition on and off a few times and it prints the codes out on the odometer which is very convenient. Is there any way for me to read the codes on my '04 coupe without using some type of interface?
Old Apr 13, 2009 | 08:08 PM
uf20wop's Avatar
you could try resetting the ecu, then seeing if it comes back on
search for easy ecu reset
Old Apr 13, 2009 | 09:19 PM
nibble's Avatar
The "easy" ECU reset worked. Thanks.
Old Apr 14, 2009 | 09:00 AM
uf20wop's Avatar
welcome
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
