ENGINE OVERHEATING! need ur input
Old Apr 26, 2009 | 01:04 PM
t2dato's Avatar
I just installed a motordyne 5/16 plenum spacer with the iso thermal gasket and a NISMO cold air intake and after a while my engine started overheating..if you have any idea what the problem could be please let me kno your input would be very much appreciated.
Old Apr 26, 2009 | 02:37 PM
xXHotelCrazyXx's Avatar
Did you disconnect any of your coolant lines that go to your plenum during the install? Hows the fluid level in your reservoir?
Old Apr 26, 2009 | 03:10 PM
t2dato's Avatar
at first i forgot one and it leaked everywhere but i already connected it..i had some loose intake bolts so i tightened them and i just ran my car for a while and it stopped so i beleive im good now. thanks tho
Old Apr 26, 2009 | 04:29 PM
Old Apr 26, 2009 | 08:57 PM
Darkstar752's Avatar
Make sure you didn't lose too much coolant.
Old Apr 26, 2009 | 09:18 PM
Dranom's Avatar
you might have air bubbles
Old May 10, 2009 | 11:52 PM
Tollboothwilley's Avatar
You probably have air bubbles from installing the coolant bypass. bleed air out..
Old May 11, 2009 | 12:00 AM
Canadian's Avatar
Canada, eh?
You have air and you probably lost coolant. You'll need to refill it.
btw what is up with the huge increase of coolant issue threads lately?
Old May 11, 2009 | 12:08 AM
summer is coming...
Its weird...I have been having heating issues lately as well. Mine is running normal for the first 25 min then after that it will start to heat up so I have to turn off my AC. Its been 105* here in PHX lately. I think I need to try burping the system a different way than I have in the past.
G35Rican
Jul 31, 2024 01:37 AM
magnetism80
Feb 1, 2019 10:00 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
mikemf8
Forced Induction
Sep 4, 2015 12:11 AM
