Quick Synthetic Oil Question
Old Apr 26, 2009 | 10:04 PM
CLEANBS's Avatar
My car has 52K miles on it and I have been using regular oil
Are their any disadvantages for me to switch to synthetic at 52K miles?
thanks
Old Apr 26, 2009 | 10:09 PM
Swivel's Avatar
Moderator
Absolutely no disadvantages. Search and ye shall find.
Old Apr 26, 2009 | 10:11 PM
CLEANBS's Avatar
even at 52K miles of using conventional oil?
Old Apr 26, 2009 | 10:17 PM
Swivel's Avatar
Moderator
Affirmative. Never too late to treat your baby right.
Old Apr 26, 2009 | 10:21 PM
CLEANBS's Avatar
okay thanks
Old Apr 26, 2009 | 11:48 PM
teamspink20's Avatar
after u put synthetic in for the first time i would change it after 1000 miles because it will probably clean up some stuff in the motor and will probably be pretty black pretty fast. you dont have to do it but its just my opinion
Old Apr 27, 2009 | 12:08 AM
Deepdiver's Avatar
^explain how it would clean up the motor.
Old Apr 27, 2009 | 09:42 AM
on every bottle of synthetic oil it says how much better it cleans up than conventional oil. i was at a royal purple seminar like 6 months ago and someone asked the guy the same question as the OP. his answer was it was fine to do it but he recommends changing it after the first 1000 miles for the first time
Old Apr 27, 2009 | 11:52 PM
Deepdiver's Avatar
are you sure about that?
Old Apr 28, 2009 | 11:12 AM
vincentl's Avatar
If you have had regular oil changes (3000-6000), I don't see why you would need to change it after 1000 for the first synthetic change. The purpose of using synthetics is its increasing lubrication and durability, which includes containing contaminants, thereby reducing engine wear.
Old Apr 28, 2009 | 12:30 PM
hg35x's Avatar
My '04 G35X manual says not to use synthetic. Don't know why.
Old Apr 28, 2009 | 07:04 PM
superchargedg's Avatar
Best oil for any engine.
Old Apr 29, 2009 | 08:30 AM
SwanyJr's Avatar
I think the biggest reason you should change the oil about 1000 miles after you put synthetic in is due to the fact you were using regular oil before, and when you add synthetic, you will cross contaminate the two. After a bit of normal driving, drain the oil and add new synthetic in to make sure thats all ur engine has in it....just my two cents I've seen and/or read about when I use Amsoil Syn.
Old Apr 29, 2009 | 10:44 AM
Deepdiver's Avatar
nah, if cross contamination was an issue you would flush it and not even drive it a K miles. After all, they do make synthetic blends.
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
