engine misfiring after wire tuck
Old Apr 29, 2009 | 01:00 AM
EGGPLANT's Avatar
So i did a wire tuck on my car today..
i did the harness that goes across the front of the engine.. i didnt cut any wires simply unwrapped the plastic and then re wrapped it with electrical tape no wires were snipped at all what so ever..
then i went along reconnecting everything where it should reach simply to make sure everything would fit and reach..
then after everything was said and done i started my car up and it seems like its misfiring i get a check engine light.. dont know what it is simply because i dont have a OBII code reader..
i did not DISCONECT the negative battery terminal i know.. noob mistake
i then thought that maybe by reseting my ECU it would go away.. but only the check engine light went away yet the issue is still there..
the engine shakes a bit and you can tell something is off.. i know its not the connections because they all fit and they all reach.. what could it be?
did i just Eff up my harness??or even worse my car?
if anyone can help id appreciate it..
Old Apr 29, 2009 | 02:17 AM
EGGPLANT's Avatar
ROOKIE Helped me figure out the issue..
thanx every one
Old Apr 29, 2009 | 09:25 AM
uf20wop's Avatar
tell us what it was
Old Apr 29, 2009 | 10:22 AM
GreenGoblin's Avatar
The goblin resurrection
was one of the plugs incorectly plugged in the coil pack?
Old Apr 29, 2009 | 10:32 AM
EGGPLANT's Avatar
I had a coil pack plug switched... It was 4 and 6 that were swapped
The car dod sound hella mean that way do.. Like it was gonna kill something
But its all better now thanx to a fellow member
Old Apr 29, 2009 | 10:52 AM
uf20wop's Avatar
that's what i figured
Old May 3, 2009 | 07:03 AM
g35500's Avatar
you move the ground?
Old May 3, 2009 | 01:01 PM
_jb's Avatar
_jb
Photographer
Post up some pictures of your wire tuck if you get a chance...
Old May 4, 2009 | 02:49 AM
Tollboothwilley's Avatar
Post pix of the wire tuck. I need to do this. You didnt have to cut any wires??
I've seen that problem come up when the coils are connected wrong. Sounds awesome...just doesn't run good.. lol
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Silver tiburon
Sep 4, 2015 07:17 PM
ghost_g35
Aug 7, 2015 10:31 AM
