The next upgrade (advice needed)
so I was thinking about nismo cams, plenum spacer, nismo fuel pump and bigger injectors (engine)
new valve body, torque converter, 3.5 LSD, and 4.083 FD gears... (trans)
has anyone else had these mods?
also looking at the osiris flash (looking for a high 12 second car)
thinking this is gonna be around 3g's all together, what do u think?
I think you should spend some money on a tranny cooler.
I also agree with the guys...You won't be in the 12's. I bet you will be in the low 13s though. 13.2 ish.
TC will give a lot of midrange torque, the VB can cut off almost .2 alone.
I would say no to the fuel delivery components, since you are NA and as such are not even close to maxing out the IDC. Spacer sounds like a good idea, add an MREV2 to the mix and a tune and you will get much more power.
Transmission wise I'm not familiar with automatic, but as for LSD I think it's a good investment. Quaife and Cusco are good but you will have a really hard time finding a Cusco one.
