Engine swap
Old Jul 22, 2009 | 06:52 AM
Project's Avatar
Engine swap
Thinking about tt the g and i would like to put a revup in the bay. Could this be done and what would need to be changed out? I am assuming with an ecu and maybe a tranny swap this should work fine? Correct me if i am wrong.
Old Jul 22, 2009 | 12:31 PM
str8dum1's Avatar
you just need a new ECU and the longblock. A ton of work for only exhaust cam timing
good luck!
Old Jul 22, 2009 | 06:06 PM
Tollboothwilley's Avatar
REV-UP has more than just exhaust cam timing.
Stronger pistons, different cams, better springs...
Old Jul 22, 2009 | 07:42 PM
Project's Avatar
Not to mention more horsepower and a stronger block. It all seems to easy to be just an ecu and harness.
What is exhaust cam timing or are you saying those are a pain?
Old Jul 22, 2009 | 07:48 PM
155Mph's Avatar
^he's saying the main diff between stock motor and REVUP is varible exhaust valve timing (which it is, but there are other differences)
Old Jul 23, 2009 | 12:33 AM
the REVUP motor will also use wideband o2 sensors, so you will have to change out those and the connectors as well.
magnetism80
Feb 1, 2019 10:00 AM
Jnm07
Sep 5, 2015 01:16 AM
mikemf8
Forced Induction
Sep 4, 2015 12:11 AM
mikemf8
Sep 3, 2015 08:01 PM
