Improve launch in automatic g35???
Old Aug 10, 2009 | 06:02 PM
superchargedg's Avatar
^^^ Thats exactly what i thought at first.
Old Aug 11, 2009 | 02:26 PM
Tollboothwilley's Avatar
+1
I had to read it a couple times to make sure I read it correctly
Old Aug 11, 2009 | 02:32 PM
Jeff92se's Avatar
Red Card Crew
Dave should clarify. Wouldn't want anyone doing an N drop by mistake.
Old Apr 7, 2013 | 10:47 PM
AutoCoupe's Avatar
Whats up guys, Sorry for bringing up and old thread, but i myself have an 06 G35 Coupe 5AT and i am wondering. If i used the technique described above to launch, how is holding the brake different from just dropping it into D from N? I want a good launch but i don't want to break my trans...
Old Apr 8, 2013 | 12:20 AM
Tolboothwilley™'s Avatar
Don't drop it into D from N - that will shock the trans and likely cause problems.
Turn off the VDC and you might consider doing the full disable mod.
There were a lot of discussions related to the ECU cutting throttle electronically when the brake and gas pedals were both depressed. I don't remember if this was confirmed or not.
Old Apr 8, 2013 | 12:51 AM
thescreensavers's Avatar
Mr.202?
ECU only lets TB open 10% when brake is applied.
DO NOT Do a Neutral Drop, you will Kill your Torque Converter
While in Manual Mode or Drive have VDC off, Hold the Brake and Gas to 2k-3k and then let go of the brakes.
Its heats up your fluid so don't hold it for long
Old Apr 8, 2013 | 02:24 AM
herrschaft's Avatar
1) high stall torque converter
2) a tune
3) sprint booster
Not much you can do. A new TC would be the most noticeable option and a tune may help slightly. Never used a sprint booster before but others say they work.
Old Apr 8, 2013 | 10:09 AM
DidG35's Avatar
Also, at this age of vehicle, you may want to go to Autozone and have them pull any stored codes. You could have a bad/cooked knock sensor harness (or something) and not even know it if it's not lighting your SES. It's free and painless to see if anything is stored.
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
