Grinding 3rd and not the good kind
Old Oct 25, 2009 | 01:33 AM
jonesmeister11's Avatar
My car was driving fine (03 6 speed coupe) and just tonight it started grinding going into third gear. The only way I can get it into 3rd is go shift very slowly... So is it my clutch or my transmission? It is the only gear that grinds.
Thanks
Old Oct 25, 2009 | 05:17 AM
pfarmer's Avatar
Thanks
Does it grind going into third if you are stopped?
Old Oct 25, 2009 | 12:05 PM
idk I will check it and see. It started with only doing it with a faster shift, and now I have to shift very slow.
Old Oct 25, 2009 | 02:29 PM
djamps's Avatar
The 3rd (and 5th) gear syncros are weak on our transmissions. It sounds to me like yours is going...
Old Oct 25, 2009 | 10:12 PM
it doesn't grind when I'm stopped.
Old Oct 25, 2009 | 11:21 PM
pfarmer's Avatar
I would change the fluid and replace with Nissan's recommended fluid. It sounds like your clutch is ok as it is disengaging if it doesn't grind when you are stopped. Does your pedal come all the way up between shifts? If not change, flush, and burped your clutch fluid as well.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
tiguy99
Mar 1, 2016 11:42 AM
jjohns2711
Aug 5, 2015 08:58 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
