UR pulleys
Old Jan 27, 2010 | 01:40 PM
805g's Avatar
Question UR pulleys
how would one go about figuring out if a pulley/pulley bearing is going bad? I tend to get a squeaky belt, not so sure it's the belt, so i would like to check the pulley....?
thanks all
Old Jan 27, 2010 | 01:53 PM
kennymo's Avatar
Is it only on start UPS or when the car is cold.
Old Jan 27, 2010 | 02:39 PM
LordFappington's Avatar
Pulley is bad when it squeeks consistently. It happens when the belt is trying to escape the broken piece of your pulley, aka the guide. Visual inspection should confirm.
Old Jan 27, 2010 | 08:09 PM
805g's Avatar
The belts only squeak when the car is started after a couple of hours of non use. so during start-ups and when it's cold.
Jackus can you explain what i could look for to see if the pulley has gone bad?
Thanks again
Old Jan 29, 2010 | 07:42 PM
gotspeed81's Avatar
you might just need to tighten up on the belts
Old Jan 30, 2010 | 06:16 PM
kennymo's Avatar
yea your belt is either loose or just needs to be replaced.
Old Oct 13, 2010 | 10:56 PM
805g's Avatar
So i can see that the pulley is 'dry' and i assume it squeals until the metal warms up....
What type of grease/lube should i add to the pulley for some smooth operation?
Old Oct 13, 2010 | 11:08 PM
Neu Era's Avatar
Do not put anything on your belts to stop sqeaking. I would suggest taking the pulley off and putting anti sieze lube on it. I used white lithium grase, works fine.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
