1 step colder plugs
Old Mar 11, 2010 | 05:12 PM
kennymo's Avatar
1 step colder plugs
Being that people use 1 step colder plugs on there cars when running nitrous. One reason to help kěep the motor cool. Would it work on a motor that isn't running a bottle.
Old Mar 11, 2010 | 05:56 PM
bythabay's Avatar
yes, I've been running them on my G for a long time, no issues.
Old Mar 11, 2010 | 06:27 PM
kennymo's Avatar
Do you notice cooler temps
Old Mar 11, 2010 | 06:31 PM
bythabay's Avatar
It doesn't quite work like that. The difference between the standard heat range plugs and the one step cooler plugs is the length of the spark plug. The deeper the spark plug goes into the cylinder, the "hotter" it is considered. The plug itself will be hotter because more of it is exposed to the combustion, and thus will raise the cylinder temperature somewhat (this can cause pre-ignition). However, a plug that is too cool will not get hot enough to clean itself, and may become fouled. A plug that is too hot, will cause pre-ignition, and may become damaged.
Old Mar 11, 2010 | 06:44 PM
kennymo's Avatar
Oh I get it. Thank you. So I guess my question is. is there any point to me getting these. I need new plugs.
Old Mar 11, 2010 | 06:48 PM
bythabay's Avatar
may be worth it for you if you do a lot of highway driving.
Old Mar 13, 2010 | 12:17 AM
Tollboothwilley's Avatar
Spark plugs help extract heat from the cylinder as well, so they can help keep cylinder temps down but that normally isn't an issue.
Driving style changes things, as well as mods if you have any.
Hotter climates will do great with 1 step colder but if you are in a mild area there really will be no need or benefit.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
wow600rr
Sep 28, 2015 11:50 AM
