What does this plug go to. It's unplugged
Old Mar 31, 2010 | 09:56 AM
jwrape's Avatar
After my motor install I found this plug just hanging in the back of the intake.
Don't see anything unplugged.
Old Mar 31, 2010 | 10:45 AM
bigc's Avatar
Wings Nation
looks like one the connector for an o2 sensor, but that color is throwing me off
what is the other end of the cable connected to?
Old Mar 31, 2010 | 10:51 AM
jwrape's Avatar
Nah, the O2 sensors are totally different connector mounted up on top of the valve covers that have security connectors that have a latch. I made sure to connect those.
This can go to either side of the back of the motor and is connected to the Fuel Injector harness.
Old Mar 31, 2010 | 10:56 AM
bigc's Avatar
Wings Nation
u got me then. it looked like one of the latch connectors
IIRC from your other thread (which was impressive, btw), you kept all of your fuel stuff and harnesses from your old engine. have you thrown any codes? if you get under you car do u see any wires hanging?
Old Mar 31, 2010 | 10:57 AM
jwrape's Avatar
Thanks
Nope no codes yet.
Old Mar 31, 2010 | 11:22 AM
Glex25's Avatar
Administrator
Could it be for the knock sensor
Granted the wiring is not in the correct position there
Old Mar 31, 2010 | 11:25 AM
jwrape's Avatar
I thought about that but i remember plugging that up specifically. Because I had to remove it from the old motor and sand a good contact where it sat cause it had a little tarnish look to it. Gotta be something else, but what else is there?
GreenGoblin's Avatar
The goblin resurrection
If you are sure its on the injector harness not much.
Old Mar 31, 2010 | 11:26 AM
jwrape's Avatar
Gio?
Old Mar 31, 2010 | 11:28 AM
Glex25 = Gio
Old Mar 31, 2010 | 11:29 AM
jwrape's Avatar
Glex25 = Gio
But it's not the Knock sensor. That's a black plug that's a tad bit smaller .... It's on the same harness though.
Old Mar 31, 2010 | 11:31 AM
jwrape's Avatar
Eww wait, what does the Knock Sensor harness plug into on the car? I suppose that could be the far end of the knock sensor harness. Not the part that plugs into the sensor but the other end that connects to the car.... Where does that plug in, anyone know?
Old Mar 31, 2010 | 11:36 AM
Glex25's Avatar
Administrator
The picture i posted shows the knock sensor installed and the harness disconnected and it has a blue plug just like the one you showed just have to find the corresponding plug back there. Most plugs on this car are different so no way to mix them up so find a empty connector
Old Mar 31, 2010 | 11:38 AM
jwrape's Avatar
That's been my issue so far. Can't find another empty plug to plug into. I thought someone might know where it is in proximity.
Old Mar 31, 2010 | 11:42 AM
bigc's Avatar
Wings Nation
the pic i've attached shows the valley under the intake manifold. i have a non-revup, but perhaps that connector is in the same place on revups.
