Car having trouble starting.
Old Apr 7, 2010 | 10:13 AM
Gman88's Avatar
I have a 03 G35 Sedan and lately it has been having trouble cranking. It takes several attempts to get it started. The lights come on so I'm not sure if its the battery. It is an old Nissan battery and I'm going to get it replaced today.
I'm going to post a youtube video the noise its making.
If you listen at 0:06, that is the noise that it just keeps making and the motor will not start. Its takes about 5 tries before it will crank.
Note: That is not my car in the video, I just wanted to show the sound because I don't know enough about cars to tell you if that is the way a starter sounds or something.
Also any suggestions for a battery?
Old Apr 7, 2010 | 10:40 AM
kvangil's Avatar
1. Battery is the most obvious and cheapest.
2. Camshaft position sensor--but usually accompanied by a CEL, or some occasional/sporadic hesitation/stalling when you drive.
Old Apr 7, 2010 | 11:22 AM
Gman88's Avatar
Going to go by Auto zone after work and have it tested. I hope thats the problem. Do the OEM batteries say Nissan on them?
Old Apr 7, 2010 | 11:38 AM
kvangil's Avatar
Can't remember, but I believe so. If you're on the original battery, that's the most likely culprit.
Old Apr 7, 2010 | 08:31 PM
Gman88's Avatar
Had the battery tested and it showed bad. Got a new battery and it is still doing the same thing.
chinee
Jun 10, 2024 07:48 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
newg37
Jul 26, 2015 09:32 AM
kenthung
Jul 21, 2015 05:56 AM
