oil? need suggestions
Old Apr 8, 2010 | 06:09 PM
oscar_g-sedan06's Avatar
i have a g35 sedan 06 and since i have had it i always used synthetic 5-30....bt almost always have add a quart every about 1,500 miles..my oil changes done at 3000miles everytime i have 80,500 miles right knw.what you guys think if i switch to use regular oil... or what do u recommend???
Old Apr 8, 2010 | 06:18 PM
Jeff92se's Avatar
Red Card Crew
I use about 1 qt every 3,000-4,000 miles. I've been using 5w-30 also. I'm not as bad as you but I've always wondered why I'm using. ie.. during cold or warm states.
I got a deal on penzoil EDGE in 10w 30. I'm going to compare if going to a thicker cold weight makes any diff. If not, I might consider a 5w-40 (upping the warm weight) and see if that slows the comsumption down.
You could try a 5w40 in either synthetic or dino and see what happens.
Old Apr 8, 2010 | 06:23 PM
i have used 10w-30 once and it did stop the consumption was missing about little less than a quart at 3,000 miles better then 1,500 miles bt i dnt really knw a lot about oils so u think i would be fine using 10w-30 with no problem
Old Apr 8, 2010 | 06:47 PM
AARONHL's Avatar
My car uses about a QUART every 3,000 miles too.
Old Apr 8, 2010 | 06:50 PM
Jeff92se's Avatar
Red Card Crew
I'd like to think that maybe 1/2 quart of that is soaked up in the oil filter. You can pour a pretty big amount of oil in a new filter and the pleats soak it all up.
Old Apr 8, 2010 | 08:46 PM
Mustang5L5's Avatar
I use up a quart every 3500k miles as well in my car.
Old Apr 8, 2010 | 10:57 PM
how often u guys change your oil?
Old Apr 8, 2010 | 11:09 PM
gary c's Avatar
It's not a good idea to quit using synthetic and it's all right to switch to a different weight since you live in a warm area of SoCal. I'd use 10W/30 on you next oil change and see what results you get, you can alway go with 10W/40 if you're still using 1 quart between changes. It's also a good idea to use a quality brand like Mobil 1. WallMart has the best price on Mobil 1 I've seen. Don't consider using penzoil if you have any respect for your G35, I wouldn't even put that crap in my lawnmower!!
Gary
Old Apr 8, 2010 | 11:15 PM
Originally Posted by gary c
It's not a good idea to quit using synthetic and it's all right to switch to a different weight since you live in a warm area of SoCal. I'd use 10W/30 on you next oil change and see what results you get, you can alway go with 10W/40 if you're still using that 1 quart between changes It's also a good idea to use a quality brand like Mobil 1. WallMart has the best price on Mobil 1 I've seen.
Gary
yeah walmart has the best price on mobil 1 thats all i use...yeah ill use 10w-30 next time thankx for the help...what best oil filter u recommend i use the fram tough guard..
Old Apr 8, 2010 | 11:22 PM
gary c's Avatar
There's a lot of quality oil filters on the market Fram isn't one of them. Mobil 1, K&N and Wix are fliters better than what you're using.
Gary
Old Apr 8, 2010 | 11:23 PM
thescreensavers's Avatar
Mr.202?
0.39 Quarts of oil is in the Oil filter.
Old Apr 8, 2010 | 11:33 PM
Gary
ILL TRY MOBIL 1 FILTER NEXT OIL CHANGE THANKX...
Old Apr 8, 2010 | 11:40 PM
C63someday's Avatar
AMSOIL!!! 5w30, hands down the best oil on the market, If they put it in a yamaha r6 that revs to 16 000k then its fine for my 6500k,
"• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first"
Srry if im not allowed to link to there site in the forum.
http://www.amsoil.com/storefront/asl.aspx
Old Apr 8, 2010 | 11:50 PM
Swivel's Avatar
Moderator
^^ That's what I run, too. Wix filter currently.
Old Apr 9, 2010 | 08:02 AM
Mustang5L5's Avatar
I set my maintainence reminder in my NAV at 3000 miles. By the time i get around to it, i've prob driven 3500-3750 miles.
I use Castrol conventional and a Purolator Pure 1 filter. I'd run synthetic...but 3000 miles is a month of driving for me...so it would get expensive fast. Besides, nothing wrong with conventional oils if you actually change it frequently. My oil is still semi-clear when i drain it.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
