vq35de swap questions help. . .
Old May 12, 2010 | 04:32 PM
240kiid's Avatar
Hey I came across a problem. I was gonna swap out my motor from my 07 g35 coupe to my 03 350z. . Its the same exact motor but someone told me that the sensors are different because of the newer year and so and i wont be able to reuse the wires from the 350z that all the wiring has to be swapped from the G to the Z but i think thats bull**** so if someone knows please let me know.
Old May 13, 2010 | 05:08 AM
240kiid's Avatar
can anyone help me???
Old May 13, 2010 | 05:15 AM
HenryLee's Avatar
why would you swap a 03 motor into your 07 g35?
Old May 13, 2010 | 05:21 AM
240kiid's Avatar
You didnt read it right. . Im swapping my 07 motor to my 03 350Z..
Old May 13, 2010 | 06:44 AM
G.Mello's Avatar
you will have issues with the engine harness. 05-07 6MT's have exhaust timing on the cams so they will have more sensors, and your older 350Z wont have the connections for them. Now If the the 07 engine came out of an automatic, it wont matter because all auto G/Z's came with the 280hp engines, same as the 03-05 Z 6mt and 03-04 6mt G's. The swap would work you just wouldn't be able to use the exhaust timing for full functionality.
Old May 13, 2010 | 07:55 AM
jwrape's Avatar
You are referring to the Blue and Green sensors here..
Old May 13, 2010 | 10:53 AM
Tollboothwilley's Avatar
If the 2007 is from an auto COUPE then it will work.
Old May 13, 2010 | 02:03 PM
240kiid's Avatar
no mine is stick FAWKKKKKKKKK MY LIFE!!!!!!!!!!!!
Old May 13, 2010 | 02:19 PM
PerpetualVisitor's Avatar
that has to be one of the bigger fmls i've seen
Old May 16, 2010 | 02:21 PM
BremboLuv's Avatar
you will need the 07 ecu and harness..
Frostbite91
Aug 12, 2015 05:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
