10w-30 Oil OK in Sou Cal ?
Old Sep 24, 2004 | 07:59 PM
WalterRego's Avatar
I am getting ready to do my first oil change. The manual is a little unclear on the suggested weight for motor oil. It specifies either 5W-30 or 10W-30. It seems to me that in the temperate Sou. Cal. climate that it isn't necessary to go to an oil that is as thin as 5 weight on the bottom end correct ?
I'm thinking 10W-30 is OK and the 5W-30 is better for parts of the country that experience snow and/or below freezing temperature for a few months per year.
Comments ? Thanks.
Old Sep 25, 2004 | 12:09 PM
iafzal's Avatar
Re: 10w-30 Oil OK in Sou Cal ?
Its ur call but I use 10W-30 in summer and 5W-30 in winter
I am in NorCal so temps are not too far off.
I suggest using 5w-30 initially as the clearance in the engine will be much tighter, later after 10-15k maybe you can think about going the 10w-30 route.
2003 G35 Black Sedan
Old Sep 25, 2004 | 07:55 PM
karlhungus's Avatar
Try to stick with 5W/30 unless you expect outside air temp. to get over 100. It pumps faster upon startup when almost all wear occurs. If you live in Phoenix or LasVegas, then a 10W/30 or 10W/40 is OK in the summer. Never use 20W/50 in a VQ in any weather. Too thick and doesn't get where it needs to be fast enough.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
