Coolant drain and refill question....
Old May 21, 2010 | 11:45 PM
WACK BEATS's Avatar
I just drained the coolant from the radiator and it looks like there is more coolant that drained than the 1gallon i have to refill it? Do i need to buy more coolant or is 1 gallon enough?
Old May 22, 2010 | 01:26 AM
WACK BEATS's Avatar
How much do i have to fill the radiator?
Old May 22, 2010 | 01:56 AM
SiouxFallsG35's Avatar
The FSM says 9.25qt for engine coolant capacity but that's for the total system. I'm pretty sure when I dropped my radiator coolant it was less than 2 gallons.
Old May 22, 2010 | 07:55 AM
WACK BEATS's Avatar
thanks!
Old May 25, 2010 | 02:02 AM
Bucszilla's Avatar
You do know that you mix half distilled water and half coolant, right?
That would equal two gallons...
Old May 25, 2010 | 09:33 AM
You're assuming he didn't buy premixed. Good point to double check.
Old May 27, 2010 | 10:21 PM
Bucszilla's Avatar
Yep...actually even if it was premixed he'd need to buy two gallons. I just did this last week and it took over 1.5 gallons to fill including the reservoir.
Old May 28, 2010 | 02:11 AM
WACK BEATS's Avatar
thanks...i bought pre-mixed
G35xdriver04
Nov 7, 2015 08:31 PM
BradMD_96
Oct 6, 2015 09:31 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
G35CO
Sep 4, 2015 09:27 AM
