Whats causing the squeal? pulley or belt.
Old Jun 30, 2010 | 02:19 AM
cguerrero523's Avatar
Ok so im getting this really annoying squeal on cold starts, which last maybe 1 minute. Its kind of random though, sometimes its just a chirp or a real loud squeal. The funny thing is is if i give it a good amount of gas it will go away almost instantly. I bought some cheap lubricant from WM the other day and sprayed the belt and i made it louder for a sec. then went away immediately. What do you guys think it is?
Besides being annoying, its pretty embarrasing starting it when i leave work. Makes my car seem like a POS when i start it lmao.
Old Jun 30, 2010 | 06:17 AM
LMG_35C's Avatar
Belt tension may just need to be adjusted. If you have more than 60k miles, may need new belt. look for cracks and fraying.
belt lubricant / conditioner -- don't over do it.. adjust the belts first
Old Jul 1, 2010 | 01:26 AM
jonnylaw's Avatar
^^+1. Check belt tension and replace belt(s) if necessary.
Old Jul 1, 2010 | 11:16 AM
Tollboothwilley's Avatar
The belt is causing the squeal but the pulley could be causing issues to the belts.
I would loosen up the belt and pull it off the idler pulley and spin it. If it spins freely with no noise then it is still good. If you hear a rattling sound the bearings are bad and the pulley should be replaced.
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
dcsbh1
Oct 1, 2015 03:15 PM
aaron3719
Sep 29, 2015 10:12 AM
3000vr4tt
Sep 7, 2015 12:48 AM
