What spark plugs work best?
Old Nov 18, 2010 | 11:11 AM
Rusaw's Avatar
Now everybody wants the best parts for thier car, but small things are often over looked. Im lookin at changein my spark plugs and im not sure of which will work the best for me. When should i get a colder plug?
Old Nov 18, 2010 | 12:41 PM
Junkyardspecial's Avatar
Colder plugs are usually only made for more modified cars, if you have cams, or FI. there are other reason why you should get them, but that is the basic use; to prevent detonation. Id recommend Iridium NGK's as they always have good reviews and always make good spark. If you want longer life go with platinum, you wont have to change them for about 100,000 miles.
Old Nov 18, 2010 | 01:30 PM
Rusaw's Avatar
ok yeah right now i dont have many mods. intake, headers, plenum spacer, and test tubes.
I just found it funny how nobody ever talks about them. they are rather important. theres a good article in this months Dsport mag. I just wonder what the people think
Old Nov 18, 2010 | 01:32 PM
The OEM plugs are actually very good too, you really wont notice much of a difference in these engines.
Old Nov 18, 2010 | 01:35 PM
LightsOut's Avatar
SIETESG
NGK's, which I think those are actually oem's.
http://www.ngksparkplugs.com/part_fi...engineid=26078
Old Nov 18, 2010 | 01:51 PM
MM_G3520's Avatar
Ehhh, I wouldn't want to leave mine in for 100k!
Iridiums are great!
Old Nov 21, 2010 | 03:24 PM
seymore4's Avatar
m56
Nissan claims the plugs are good for like 100K miles, but from my experience most cars need them changed a lot sooner. Especially if you've done any kind of breather mods (spacer, exhaust, etc) it has a tendency to run lean and you will need new plugs a lot sooner
Old Nov 21, 2010 | 08:25 PM
V35 Skyline GT's Avatar
6MT Coupe
Iridium is less conductive than Platinum, but Iridiums will last longer. I stick with Platinums and change 50-60K. 100K on Platiums...nope, Iridiums probably would make that though.
Old Nov 21, 2010 | 09:21 PM
Tollboothwilley's Avatar
I think you got that backwards...
Platinum will last longer but Iridium is more conductive.
Copper is the most conductive but has the shortest life as well - about 30K miles.
If you live in a hotter climate you can also swap to 1-step colder plugs if you want. Not a bad idea if you have done a lot of mods and are in Phoenix or Vegas or other similarly hot climates.
Old Nov 22, 2010 | 11:06 PM
Blackbird V35's Avatar
NGK Coppers, thats all I run
Old Nov 30, 2010 | 11:00 AM
GHOS7's Avatar
Dude... use stock plugs if your VQ is stock. It was engineered to work with them. Only thing I would do differently if I was you, is change them after 50-60K instead of 100K. Getting power gains from just spark plugs on a stock motor is wishful thinking. Don't waste your money man.
Old Jul 28, 2014 | 04:20 PM
danoman32's Avatar
Stock work best. I'm installing 1 range colder plug when I install my TT. NGK PLFR6A-11
Old Jul 28, 2014 | 04:21 PM
gary c's Avatar
With all the breather mods there's a very good chance you'll run lean and throw an error code! Best way to fix that is a Osiris tune which will give you major WHP gains. You still won't need plugs other than what your G came with!
Best advice ^ run what your G came with! Unless you have severely modified engine what Nissan installed will work fine!
Gary
Old Dec 25, 2014 | 07:25 PM
Jaycee0403's Avatar
What about pulstar? There like 15 each and I wanna get them
Old Jan 4, 2015 | 03:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
Do a search on here for threads on Pulsar plugs. The suck and several members have had issue with them exploding and causing engine failure.
